googleborg
- Nov 10, 2009
tried applying the slightest amount of glue over the hole?
I don't understand how you could even do damage to the driver, because in his video he rips his out which seems quite violent compared to just nicking the driver like OP did.
ok so what your pushing holes through is the cloth?
using the 1/8" connector on your MS1i's should do some excellent venting just like it does on my SR60s
Bilavideo who invented the mod, recommends a ballpoint pen because the increasing width as you go upwards actaually makes it impossible to hit the driver, which makes sense if you're worried about your hand eye control.
It's best to use tweezers to peel away the felt and uncover the holes. Poking them makes the felt fall onto the driver area and can cause some issues with sound, just sayin.
Quote:It's best to use tweezers to peel away the felt and uncover the holes. Poking them makes the felt fall onto the driver area and can cause some issues with sound, just sayin.
how do you do this with a tincey hole?
What did you use to make the holes?
Also I seem to be having the same problem. Though I have heard this sort of thing before, it could be due to hair on the driver. It is possible to remove them. Right now I am looking under a microscope projecting light from behind and can see in one of the holes that there is a very obvious hair vibrating with the driver. The trick is getting it out.
