AKG K701/K702 vs. AKG Q701?
Dec 19, 2014 at 6:27 PM Post #226 of 237
I have no headphone amp/soundcard for PC/DAC/X1 etc.
Just a cheap mp3/flac player, laptop and a Yamaha RXV-475 AVR/PS3 for Films
Q.  Would it be a waste getting such a high end product, I would use them for Music-some film watching. Is the build quality good?
Q. I can get the AKG 551's/AKG Pro 612's for much cheaper, has anyone heard them all?
I own K702, K500, and until a few weeks ago, K612. Given your application and source material, I'd strongly suggest the K612. It's the most forgiving out of the bunch and would be a better match for your receiver. Good luck.
Dec 19, 2014 at 6:42 PM Post #227 of 237
£120 AKG Q 701
£105 AKG Pro 612
£70   AKG 551
Hi Shaffer, these are the price differences, the 551's are closed but i can't try any of them out (that i've found yet anyway). Why did you get rid of the 612's? My only concern is that it is described in some reviews as having a bit more "bass and musicality" which is a problem i had with the UE 6000's, of course this may have been reviews directly comparing the 612's and 701's.
Thanks.
Dec 19, 2014 at 7:20 PM Post #228 of 237
£120 AKG Q 701
£105 AKG Pro 612
£70   AKG 551
Thanks.
A friend liked the K612 a lot more than I did, so I gave them to him. The K612 is warmer sounding than the K702 and a bit less resolving, which in your case is a plus (given the source material). The K702 is a relatively thread-bare sounding piece, so keep that in mind regarding the comparison.
Dec 21, 2014 at 7:03 PM Post #229 of 237
Thanks, for some reason i seem a bit hung up on the removable cable, but the 612 looks good. Did your 612/702 work at all well with low impedance sources, mp3 type devices, still struggling with the impedance/Ohms aspect. cheers.
Dec 21, 2014 at 7:07 PM Post #230 of 237
I don't have any MP3/portable devices. Can't really answer the question. Sorry.
Apr 17, 2015 at 6:37 PM Post #231 of 237
They are the same except audio specs and components except for the Q on the ear peace… I have both par my K701s have a more natural sound because they are burned in and older, The Qs are a tad more aggressive on the mids and highs but again its because they are new and not used much. I just got them as a back up. The 701s are the best phones I had under 1500.00 as for as natural sound in concerned. What you hear is what it is. If the mids are harsh the mids were mixed harsh, if the bass in muddy the bass was mixed muddy. I mix and master for a living and needed a good set of un colored phones and these are the ones, actually more accurate  than my AKG k812s
May 24, 2015 at 4:14 PM Post #233 of 237
I totally agree.  having a hard time deciding whether to sell my K812 or sell my K701.  Despite knowing my K701 is better for the job.  I still have my T90...which is more revealing than both of them.....so i may keep my K812 as my "fun" headphone.
K701 is really an all-time great.
Aug 23, 2015 at 4:42 PM Post #234 of 237
I recently purchased a Q701 and I must say it is a pleasure to listen to although I am still on the lookout for a portable amp to drive it properly whilst on the move. The only niggle I have is the bumpy headband and the fact that the stock cable are rather long. I would have liked a short and a long cable.
Jan 17, 2016 at 5:30 AM Post #236 of 237
I must have the only K701 that is warmer than a Q701.  Even swapping the pads and foams, it's still obviously warmer.  Both are Austria versions.  The K has a lot more hours on it than the Q, but the Q isn't new.  Maybe I'll try that 1000 hours of burn-in I've heard about.
Anyway, just odd.
