pacman46
- Dec 30, 2012
I may be wrong. But i think at this level there really isn't ant better just different. Imo depends on what you like and want ☺
they don't look like the tf10 which are longer, made of blue plastic and stick out of the ear noticeably. now they were called frackenstein's bolts for good reason.
yep - until the nozzles snapped off
Super Glue worked for a few times
brilliant!
Just let it dry before you put them in your ears.
Hi guys, i'm thinking about getting myself a pair of K3003 to end game but also consider buying a custom as well (e.g 1964 V6S)I don't know but will the K3003 be nearly as good as the V6S cause both of them are priced similarly in Australia (700 USD). Also have anyone own the K3 and has a chance to hear the Final Audio VII, which i think should be on par with the K3 after i read those reviews (i just loved how the VI sound)
Just wonder about the soundstage on both, i just need the one wider than my Asg 1plus n ckr9 ltd
