james444
- Aug 25, 2004
Is this a fair comparison though. Is the 535 measurement not done with the Shure foam plugs? Stick foam plugs (Comply or otherwise) on any earphone and the isolation will dramatically improve, especially in the low frequencies. I could share some of my own measurements, but I'm not sure I can actually.
It wasn't meant to be fair (this ain't my measurements after all), rather to give someone who has no personal experience with the K3003 an idea of what to expect. Moreover, I also mentioned that the AKG's isolation can be improved if you use deeper sealing tips. That said and measurements aside, I personally own the SE530 and K3003, have tried all kinds of tips on the AKG and nothing has brought the latter's isolation anywhere close to the former's. The K3003 are vented and designed for a shallow fit, and even with silicone tips the Shure's isolation is subjectively a lot better, because of its deeper fit and the housing providing part of the isolation.
Don't get me wrong, I'm not saying the Shures are better than the K3003 overall (actually not by a long shot), but once again, I wouldn't go for TOTL IEMs with lukewarm isolation if I planned to use them primarily in noisy surroundings.
