Got a very cheap pair of of sextetts off german ebay lately for 23 euro sth plus shipping (cheap inside germany). Were advertised as K240 with intermittent cable failure but pic looked like LP sextett with solid headband.
Got them today, as expected the pads and elastics are shot and they had a bad recable job done - every single solder joint was cold and to top things off the left cover over the cable entry had the screw broken out and was superglued shut 8-O
Pried open the cover and they turned out to be MP (passive radiators white front and red back) despite the solid headband w/o holes. Grilles are glued on this one. Cleaned out the foam at the start to getting gunky, reassembled and redid the cabling. For now I swapped the cover over from the other side.
I will get new pads from www.thoman.de - they have them in stock. No idea where to get elastics in germany or even a new cable port cover... Ideas where to get those in germany or europe are very welcome.
Otherwise i'll have to glue the cable port cover too - although rather on the side opposite of the cable entry - you don't open this so often...
Listening to 'em right now with my O2 con ODAC and man, do they sound nice despite the flat pads
Congrads I bought my pads direct from AKG off amazon. Full pads make a big difference.
