I got a chance to try AirPods Pro, and I wasn’t as impressed as I thought I’d be. Firstly, the fit is less transparent than I expected: you can definitely tell when they’re in your ears, unlike AirPods (at times) or Powerbeats Pro. The sound quality was perfectly adequate, but there was no particular aspect of the audio that stood out or blew me away. I was expecting more out of a Pro model. It does faithfully reproduce the entire frequency range for the most part though, it’s just not particularly detailed or exciting. Maybe if I had more time to test I’d have a better experience and grow to enjoy them. For now though my impression is that even first-generation AirPods have a punchier bass, but it isn’t as deep. The mid-range and treble are also more hyped on the original AirPods. ANC is very impressive for an earbud of this size, but it’s not as good as Solo Pro — which is understandable since it’s a full-sized (portable) headphone. I should note that I tried the ear tip test and didn’t get an adequate seal in my left ear, which may have impacted my testing.
Powerbeats Pro on the other hand had a noticeably deeper bass with a brighter treble and a more exciting mid-range as well as a more open soundstage. The bass on AirPods Pro seemed recessed in comparison, and Powerbeats Pro only has a mild sub-bass boost. Regardless of that, it’s still a bit of a toss-up which has better sound quality but upon first impression Powerbeats Pro seemed cleaner. Neither are phenomenal high-fidelity headphones, but they don’t have to be. Also of note is that Powerbeats Pro has minimal passive noise isolation, which is useful for fitness use and feels like more of a direct upgrade to AirPods. In fact, AirPods Pro has a relatively high level of passive noise isolation. They’re a different product than AirPods, so it’s understandable that it isn’t technically a third-generation product.
The sound quality is slightly better with ANC disabled. Transparency Mode works like magic. It isn’t 100% as natural as simply pausing music on a regular set of AirPods, but it’s close. Probably 95% transparent.
Solo Pro is the most underrated product out of the headphones that Apple/Beats released this year. It has the best sound quality of the three across the frequency range, with superb ANC performance. Still, I’m not sure I would choose it for the same reasons I would choose Powerbeats Pro or AirPods Pro. I’m trying to justify a place for it, it’s definitely among the best Bluetooth headphones I’ve heard.
