Xinlisupreme
1300ss should be a great choice on the go
1657cu I’m sure Shoul be a bit dark for my taste
Very happy with 1677ss
Different flavors available, that’s nice1300ss should be a great choice on the go
Which driver did you listen to? The SS or the copper finish?HS2000MX a tad too stiff in the bass, still enjoy the HS1300SS more even though detail wise HS2000MX is a clear upgrade.
Only the SS shell casing so far. According to my dealer(zepp and co) there is no CU shell casing or plans to release it yet and that was just a audio show thing to get feedback.Which driver did you listen to? The SS or the copper finish?
https://www.head-fi.org/threads/acoustune-impressions-thread.911169/post-16595430
Upcoming driver for the HS2000MX?
That being said if you are getting HS2000MX you should have aet07 tips on hand. The new xet7 tips have god awful fitting since they flare out like a flat mushroom ensuring only very shallow fit and a very spiky treble response. With aet07 it sounds like a interesting mix of planar bass and dynamic vocals with abit of early treble roll off for quite a nice cenamatic experence. That being said I dont reallty like the way it protrays the bass as a ultra quick decay wide and slappy, likely a side effect of the Be coating but I'm sure it would be good for stuff like uptempo hi-tech and breakcore trance. Not so much for strings where the bass feels disconnected from the main body of the sound and dies too fast.
Otherwise vocals male or female I have no complains. Its a very good articulate driver. The only minor complain I have but its not by design so I cant falt them that much is the deeper fit you get via tip rolling the darker it gets.
That being said I'm still eventually planning on getting them because the vocals on these are really top notch and beats multi ba iems .
Ah good point. Makes me want to get one sooner than later. Also kind of reminds me of how the SSR broke in where at the start it was very stiff and then over the course of a month the bass started loosening up and producing better bass texture. Is that the case with the HS2000 as well?Seems Zepp haven't properly weathered their in ear headphones.
They are micro mechanical articles after all.
Sony EP-EX11 kills those excess trebles - that's what I'm using.
That's the Acoustune house sound right there. A very realistic voice, w/o partisan to male or female.
For my set, very realistic percussion, strings and "floor standing" bass (mid bass).
A very large sound field sealed the deal for me...
