Tinnitus Man
Just a thought, is burning-in likely to improve the volume, or should the level be ok right out of the box?
Ok, so I'm underwhelmed.
I bought this player on the primrose if having great sound quality. It looks as though the new AR Pro Player just doesn't do playlists (and my work based listening is entirely playlist driven as I's dumb to go back to the player and choose a new album whenever the last one has finished).
And the volume. On the unit I have here, the sound is barely hearable with the volume set to 50%. To get a reasonable sound level I need to raise it all the way to 90%. I've tried this with both my headphones (nothing special here) and they're both the same.
I think that yours is working better than mine. Pausing/unpausing doesn't stop the quietness.
This device has been out for 18 months or so now, so I'd have assumed that the firmware would have reached a stable point by now. It's just not there. The system crashes on occasion, the "scan database" feature is flakey (sometimes it works, sometimes it keeps asking you over and over again, sometimes it says it's still scanning. Administering playlists is painful (at least with my AK Jr, I can just upload playlists from the computer).
The overriding issue for me is the sound. I don't know whether this is down to the firmware or a manufacturing defect, but even when I raise the volume up to 75-90% to make it listenable, the quality is just not there (it's like butter spread too thin).
I really did want to love this device. Even with the software issues, I would have kept it if the sound was good.
I'm going to return this while I still can.
Burning-in will not affect the volume.Just a thought, is burning-in likely to improve the volume, or should the level be ok right out of the box?
I'd suggest you install any 3rd party music player and then test the volume level with that. At least that way you should know if the hardware is defective or something to do with AR Player.I've just compared the volume levels between the AK Jr and the AR-M20. I think I'm going slightly mad as the AK is the same - my usual volume setting on that is set at about two third of maximum, so the M20 is similar in that respect.
I've had poweramp on my previous ZX2, and that was a nice player. What I'm uncertain about is whether it'll bypass the Android sound stack in the same way that AR Player does.
AK and AR both have similar sounds as well. Now I'm thinking that maybe my tinnitus is especially bad right now (sounds normally cut right through the tinnitus I have, but sometimes I'm deafer than normal).
I'll take a punt and stick with it for a while. I have a HiBy R6 on order in the meantime, so I'll keep whatever device I like the best and sell the other two.
Strangely, I haven't really had any software issues with mine. The only problem I have is that the Bluetooth connection is really weak.Ok, so after a day's use, this player is really growing on me. I let a colleague here at work have a listen and he reported that it sounded great, except for the bass sounding a bit weak (but then again, my ON2s aren't bassy cans, so that's fine).
I did try downloading HiBy player, but it didn't work out too well (music just cuts when I change the volume).
AR Player Pro seems to be working ok now, as flaky as it is. I really wish that the software on this player was more stable, and I guess I was a little vain in assuming that after a year, it would be.
Indeed, the battery is a huge win on this device. I love the fact that I don't need to bother shutting down and booting up when I use it. Just tap the power button and it instantly comes to life.The more I listen to this DAP, the more I like it, the sound is really engaging, detailed, fresh. It seems to improve with volume (although I can only go so loud in the office).
The lack of a hardware play/pause button is a bit of a pain, so I've enabled the developer options in the settings and enabled the "Stay awake" option. This stops the screen from blanking out when the charging cable is being used (I just leave it plugged in while I'm in the office).
Great battery life as well (although I have WiFi and BT turned off).
