The 3 shades of Vido
White one was recabled with the stock Benjie cable + replacement Rhodium jacks. Blue is just a cable switched with a generic cable from Taobao and the Black was a mic version but i switched with KZ cables.
Bass-wise, the White + Rhodium is the winner with the other 2 alot behind. Mid-bass wise i find the Black KZ to be super solid, and the Blue to be the most disappointing.
Trebles: White one is the clear winner again, with better clarity in the highs.
Seperation: The White one also tops the other 2, idk at this point if its a placebo effect but probably due to the trebles being clearer,. The mids transition to trebles is much more defined (I tried Horse Print Dress by Corinne Bailey Rae).
Engage-ness: The White one still tops the other 2. I find the sound to be more forward, and has the aggressiveness and tightness to make the music that i listen to much more engaging (mostly Rock and some Pop) The 2 other sound more laid back, with the Blue one pretty much the worst performing here. Its lacks the compactness and is too airy for my liking. I am not too sure of its the way i tie the cables in the housing that is causing this but i may try to switch the cables when i have the time. The Black KZ is probably 2 steps ahead of the Blue one, and the White one is probably 5 steps ahead of the Black. The Black is less airy, and i kinda like the acoustic feel to the sound, not that the Blue one doesnt has it but this one just does it better.
Overall i am awed by just the jack switch which i will test out on the Blue one and compare it against the Black one to see if it really improves the sound by such margin. The jack switch is like removing the limitator or like adding in a seperator that makes the music more defined. Till then i will just enjoy the White Vido
And lastly, i must say the Vido is just too damn good.
