6SN7 Tube Addicts
Oct 7, 2016 at 9:25 PM Post #5,971 of 7,413
My understanding is that the ECC 32 draws more amperage than a 6SN7, I don't recall what the ECC33 draws.  I am fortunate to have very good examples of both.  The 32s have more gain which sort cheats,  you might conclude it has a bigger slamming tube, but actually hasn't made me think so.  The ECC 32  does have a certain "gravitas"  not seen in the straight bottle tubes.  The ECC33  sound is more like a regular 6SN7, with an emphasis on clarity, midrange energy and detail retrieval.
I have only 4 pairs of the Tung Sol GT round plate.  Which BTW are always in black glass so if you have a true  TS RP you don't need to add BG, people please.
2 of the pairs were bottom feeder tubes I bought a decade or more ago, only one other pair proved to be a really good sounding tube.  I have bought a pair of very original TS gts from military stock which are stupendous.
I am holding back my thoughts on these RPs because I Iwant to see what others say first,
Oct 9, 2016 at 10:33 PM Post #5,972 of 7,413
This thread has gotten pretty far afield from 6SN7 tubes.
Oct 9, 2016 at 11:03 PM Post #5,973 of 7,413
There are many amps though where the ECC3x tubes can be used as direct replacements for a 6SN7. I really like some 6SN7 tubes, but I just happen to slightly prefer the ECC3x range of tubes in my amp.
Oct 10, 2016 at 1:24 AM Post #5,974 of 7,413
Im really going to buy a pair of the ECC32 since ECC31 didnt work on the Glass.
On another note, I received the NOS TS BGRP tubes, and the hype is real. I wasn't expecting it and felt like they might be over hyped, but apparently not.
I agree the TS BGRP are very nice tubes. There is clarity/transparency with a touch of warnth and good frequency extension top to bottom. Same with the 6f8g version.  If you can try the ts bgrp 6sl7/6su7 they are very smooth sounding tubes good but not quite as transparent as their 6sn7.
Oct 10, 2016 at 12:16 PM Post #5,975 of 7,413
As I said  there are differences in the ECC3X tubes. The ECC 32 and 33 I have described above.  The ECC34/35s are more like a 6SL7s.  There is a wealth of information available but most it deals with technical matters that are inaccessible to non  EE types or even pretend EE types like myself. ( I try but just can't figure this stuff out on my own, would love a podcast or whatever it's called to have it explained.)
Nonetheless  you might want to try a search in the Tubes Asylum of Audio Asylum.
Oct 10, 2016 at 12:39 PM Post #5,976 of 7,413
  I hope you realize that the differences in the ECC3x  tubes is significant.  The commonplace analogy is that the ECC32 is sort of like a 6SN7 but draws more current and( has a greater Mu factor I think).    The ECC33 is also said to be an approximation to the 6SN7 as well.  Since you prolly like a graphite shaded tube with a nice curvy figure the ECC 32 may be  more aesthetically pleasing.  The ECC33s I own are straight sided and clear glass.
Whereas the ECC34/35s are more like a 6SL7s.  There is a wealth of information available but most it deals with technical matters that are inaccessible to non  EE types or even pretend EE types like myself. ( I try but just can't figure this stuff out on my own, would love a podcast or whatever it's called to have it explained.
From what I understand, the ECC31 is exactly similar sounding to the ECC32 which just has separate cathodes, which are not tied together like they are on the ECC31.
Not entirely sure what the differences between the ECC32/33/34/35 are.
Oct 10, 2016 at 12:51 PM Post #5,977 of 7,413
https://frank.pocnet.net/sheets/154/e/ECC32.pdf
https://frank.pocnet.net/sheets/129/e/ECC33.pdf
https://frank.pocnet.net/sheets/129/e/ECC34.pdf
https://frank.pocnet.net/sheets/154/e/ECC35.pdf
Oct 10, 2016 at 2:36 PM Post #5,978 of 7,413
Oct 10, 2016 at 6:57 PM Post #5,979 of 7,413
I started a 31/32/33/34/35 thread here:
http://www.head-fi.org/t/808322/ecc31-ecc32-ecc33-ecc34-ecc35-tube-addicts/15#post_12839415
Oct 31, 2016 at 5:51 PM Post #5,980 of 7,413
Hi guys, I was wondering if you might be able to help.
I was thinking of trying some 6sn7 tubes in my LD MKIII via an 6sn7 to 6cg7 adapter, I have read some of the reviews and comments on Head-Fi of the best sounding tubes to go for but they all seem to be quite pricey, ie north of £30/$40 each, I have noticed however you can pic up russian versions on ebay for well under £15/$20 each, are these worth trying?. I'm after something fairly warm, detailed and with decent bass, any advice, recomendations would be very appreciated!.
Nov 7, 2016 at 10:12 PM Post #5,981 of 7,413
Anyone knows how the Marconiphone B36 (12V) compare to the likes of BGRP, KenRad VT231 and ECC32?
Nov 9, 2016 at 11:27 AM Post #5,982 of 7,413
In my opinion, compared to the other drivers you list, the GEC/MOV B36 is a bit thinner in the upper bass and midrange with very airy highs. It is a unique sound with a lot of appeal to detail freaks. However, I find it to be very system-dependent. For example, to my ears, the B36 really shines with 5998 power tubes and a Cossor 53KU. On the other hand, again in my experience, running the B36 in a system with either, or both, the GEC/MOV 6AS7 and/or GEC/MOV U52 is just too thin and too airy. Too much "GEC Goodness" so to speak. lol. But of course, my ears and my gear. YMMV. :)
Dec 2, 2016 at 11:51 AM Post #5,983 of 7,413
My 1943- RCA 6SN7-GT.
S.
http://i602.photobucket.com/albums/tt104/TDL-STUDIO/15235449_10209877452567360_2351080734093310933_o_zps6h7vdsuo.jpg
http://i602.photobucket.com/albums/tt104/TDL-STUDIO/15289079_10209877457447482_6077754989673961654_o_zpswbawajlf.jpg
http://i602.photobucket.com/albums/tt104/TDL-STUDIO/15289094_10209877455447432_2539820151404376157_o_zps8gjtz4kf.jpg
Dec 16, 2016 at 7:46 AM Post #5,984 of 7,413
Yes the aforementioned grey glass RCAs if you can get them at that price, are often described as lush, whatever that sounds like. More commonly at that price Sylvania GTBs, green lettering if possible which I find sound full rich and mellow. Trailing but really not as bad as one might think for their price Re GE GTBs, you might wan t to give them a shot.
I don't know anything about GEC B36s and have but a few examples of their rarified 6SN7 cousins.
Dec 16, 2016 at 8:35 AM Post #5,985 of 7,413
Hi, Thanks for the advice!, I missed out on a NOS pair of RCA grey glass a couple of weeks ago, think they only went for about £20/$25, 6SN7s aren't as plentiful in the UK as the USA and although a lot of sellers will post to the UK postage can be expensive plus customs, I did, however manage to win an auction a couple days ago on NOS matched pair of Philips JAN6SN7WGTA, should get them in a day or so, and I will keep my eyes open for the RCAs and the GEs.
