Im assuming the 6SN7GT is being talked about and not the CV1988 which doesnt have such good reviews.
CV1988 is nothing but another type code for 6SN7GT.
Isnt the Brimar CV1988 the 6SN7GTY? Also having a brown base and not a black base with BVA on it
http://www.ebay.com/itm/1pcs-5670-396A-2C51-Replace-6SN7-Tube-Amplifier-Socket-Adapter-Suzier-D11-/281960489973?hash=item41a627a3f5:g:VkEAAOSw0JpV5re3
Anyone try this 396a in place of 6sn7?
Using a similar adapter, I've rolled a number of 396A in my Glenn OTL with absolutely no problems. I would expect that they will be fine in your WA5LE as well. For what it is worth, I like the Bendix and the Sylvania best.
Edit: I should probably add that while I am quite sure they will work fine in your amp, I have no idea if they will sound good....
I hope you are not saying that I said that a 396A would not work well in this amp or that amp, just expensive if my memory serves me correctly. I also roll a lot tubes, the raison d'etre for the Ember.
As for your love of adapters for all causes I will now make the statement I hadn't of late. Understand that these are not my words, but those of many other audio engineer people, thus no specific attribution. That there are strongly held 'audiophile' tenets which hold that a minimum number of interfaces is desirable and that circuit paths be as short as possible. Obviously, you don't hear any artifact or appreciable negative SQ differences, and must consider these old ideas to be of limited value.
I find that the amps I am currently using demonstrate little about the 'rollable' tubes I use now, compared to rolling tubes in amps that I have used previously.
However I never said 396As or other tubes with adapters won't work please recognize that.
Logically, this makes sense to me. However, these adapters typically add less than an inch of wire to the circuit path and I seriously doubt that this small amount of wire is of any consequence in regard to SQ...
Hi g....all depends on the quality of wire used IMHO!..and some would also add solder, lol.....
