2359glenn | studio
Nov 13, 2012 at 1:07 AM Post #991 of 39,986
I've a question
 for the fine readership here. By the way, I am privileged to be able to have exchanges with all of you. Bright, experienced and welcoming, I like that in my fellow members. If you're one of the many unregistered guests stopping by with an interest in this thread, by all means register and contribute. And leave with an amp...though, you'd have to
 pay for it.
Anyway, what are some of you using in the way of audiophile friendly lighting inside the listening room?
Nov 13, 2012 at 1:58 AM Post #992 of 39,986
I am using a floor lamp Torchiere type unit to bounce the light from the celling. My new monitor has a glossy screen so can not have lights directly behind me when facing the monitor.
Nov 13, 2012 at 2:23 AM Post #993 of 39,986
Is this type of lighting/filament good for the AC, unlike fluorescent? If it helps to clarify, I'm searching for the least polluting light options to contaminate the AC. Considering, most of my sessions begin at midnight, this is critical.
Nov 13, 2012 at 2:29 AM Post #994 of 39,986
Some will use CFL Bulbs but you can use a Halogen flood bulb like in my unit. You can look at your local Walmart which has the cheapest prices for floor bounce lamps or sales in your local neigbhood. Do not ever use a SCR dimmer for the lamp in any circumstances on the same circuit branch that your audio equipmemnt.is on. I learn that the hard costly way.
Nov 13, 2012 at 3:09 AM Post #997 of 39,986
Currently using a 13w Halogen Floor Lamp. Sounds like I'm doing okay then, yeah?
If it is bright enough but I use a 90w Halogen. 13w sounds more like a CFL bulb to me.
It's an OTT-LITE floor lamp and uses a 13w halogen; mimics natural daylight...plenty bright. When I'm trying to get my groove on, after hours, don't need it TOO bright!
Nov 13, 2012 at 9:14 AM Post #998 of 39,986
Nov 14, 2012 at 7:25 AM Post #1,000 of 39,986
Thanks my friend.
Nov 14, 2012 at 12:56 PM Post #1,001 of 39,986
Tried a couple of Brimar 6SL7 one with the long 22mm plates and one with the black round plates.
The bass not as deep as with the 6SN7 but still very good, the mids are excellent.
I like them.
Nov 14, 2012 at 1:24 PM Post #1,002 of 39,986
Stavros, I am using a pair of them in my phono pre and really like them.  I am not sure what variety i have.  I will have to look tonight.
Nov 14, 2012 at 1:32 PM Post #1,003 of 39,986
Hi David, I bet the ECC35 will sound super.
I see you too have ordered a couple of 596's, I hope they sound good or else SO is in serious trouble................
I like tube ornaments anyway!
Nov 14, 2012 at 3:22 PM Post #1,005 of 39,986
Just woke up 30 minutes ago - you already made my day!
  • Back
