2359glenn | studio
Discussion in 'Headphone Amps (full-size)' started by silent one, Mar 9, 2012.
59 60 61 62 63 64 65 66 67 68
70 71 72 73 74 75 76 77 78 79
  1. Seamaster
    I had my friend made a 3D version first, but could also made into 2D format. It will be " Glenn (design) Studio ". I am away, wait till I got back.
  2. Silent One
    This is interesting...
  3. mrarroyo Contributor
    Your are! Glad you are enjoying the new toy.
  4. rosgr63
    Hi Miguel, thanks my friend.
    Here is the Rectifier table in a more presentable form.
    GR OTL Amp
    Power  Tubes
    5998
    6AS7G
    Adapter
    Rectifier Tubes
    3DG4
    YES
    YES
    NO
    GZ33/37
    YES
    NO
    NO
    5V3/5AU4
    YES
    NO
    NO
    5U8-C
    YES
    NO
    YES
    596
    YES
    NO
    YES
  5. Silent One
     Looks good to me...nice edit!
  6. rosgr63
    Thanks SO.
    I am going to draft a driver and power tubes list next.
  7. longbowbbs
    That is a very helpful chart. Thanks for creating it!
  8. Xcalibur255
    I'm going to feel guilty after you put the work in, but I would like to offer some corrections:
    - The GZ33/37 is a yes for both power tubes.  They are more than up to the task and have almost the same current output ability as the 3DG4.
    - The 5U8C is also more than up to the task for both power tubes, it has the highest current capability of any single rectifier I know of.  It is not even breaking a sweat in this amp, and that is really saying something.
    - The 5AU4 is also quite safe to use with 6AS7G tubes provided you are using the older version of the tube with the wider and longer plates.  It appears only GE manufactured them, and they are easy to spot because their glass envelope and base are really big.  They dwarf most straight bottle rectifier tubes.
  9. Clayton SF
    Eek! I've been using the 596 with an GE 6AS7GA and an RCA 6AS7G for about a year. I hope I'm not ruining the amp. It sounds excellent though.
  10. Xcalibur255
    No, you're just fine.  Glenn said so himself.  All you are doing is shortening the life of the 596 tube itself by an inconsequential amount.
  11. Silent One
    USAF-596, probably a service life of 5 years instead of 10 years he reported with the 596/6AS7G combo...
  12. Clayton SF
    Okay, thanks, SO and Xc255. I took my headphones off for one minute, saw the chart and panicked. I am now calm--and back to my headphones. :)
  13. Silent One
    You're most welcome...happy listening. I can't wait to return to the listening room @ midnight!
  14. Clayton SF
  15. Seamaster
    she is one of my favorite, but sometime make my wondering how many sunglasses she has..
