Seamaster
- Oct 20, 2004
Oh, it is a OTL, my bad.
The pair Tango cost $431.09
And lundahl LL1630-PP:
Griffin,
I don't stock these, but can get them on a special order basis. They are $150 each, plus shipping. The transformer covers are $24 each.
What power transformer you need is dependent on your circuit.
Cheers,
Kevin
Those what you see are power supply chokes the power transformer is a R-Core mounted flat under the chassis.
The amp is a OTL no output transformers.
[size=x-small]FE-25-5[/size] | [size=x-small]25 (50Hz)[/size] | [size=x-small]5K[/size] | [size=x-small]4,8,16 [/size] | [size=x-small]10Hz-80KHz[/size] | [size=x-small]160mA[/size] | [size=x-small]45, 6V6 6CW5 [/size] | [size=x-small]83[/size][size=x-small]x78x81[/size] | [size=x-small]1.6[/size][size=x-small]Kg[/size] | |
Griffin,
Cheers,
Kevin
