Thank you! Yes, it is in an adapter which I didn't even realize. I found the following info
Base | Europe side contact P8A (Au P, 8SC) (Codex=Sd) |
Filament | Vf 13 Volts / If 0.35 Ampere / Indirect / Specified voltage AC/DC |
Description | With exception of heater ratings and base, this tube is very similar to 6A6 and 6N7G.
Text in other languages (may differ) |
Tube prices | 2 Tube prices (visible for members only) |
Information source | Taschenbuch zum Röhren-Codex 1948/49 |
but would I use the 12 volt or 6 volt setting? It says 13volts above, but also says similar to 6N7G which would be set at 6volts.
Here are a couple pics a little more zoomed.
I confused myself and asked about the 1633 numbered tube I already had an answer for. What I meant to ask about was this rectifier which says 3DG4. I know nothing about it other than that it should work in the Glenn since it was included with my purchase.
