gibosi
- Oct 18, 2012
Impressions on the new valves ASAP . I enthusiastically popped the Fivres in yesterday - but only for a bit. Given what I thought of as "questionable provenance" of the Fivres and their "used" status, I gave them an hour to warm, then around an hour on the sacrificial headphones. I was able to say "quiet" and a quick listen on my normal headphones said; "probably very nice".
I then realised I had just a few hours before swapped in Mullard EL32 shoulder-types seen in the C3g slots pictured below. They are new and sound like they need time to burn in. I have had my "go-to" GEC 6J5 inputs w/ the EL32 straight tubes (postal tubes like JV has). I think that is my most reliable, often returned to configuration. I want to get the shoulder-type Mullards burned in, and to isolate the effect of just changing those tubes. Therefore, I put the setup back as pictured. I'll let the EL32s pictured go for a week of many hours/day use. THEN I'll come back to the Fivres.
I am hoping the Mullard EL32s do burn in. So far, I have not had the patience to really let the Marconi straight glass EL32s or these Mullard shoulder types really burn in because the straight postal tubes are fully settled and sound so nice in this setup! I think the EL32s run pretty cool, so it may take a while...
Here are the "GPO" postal Mullard EL32s that have maintained their position int he amp for a while now...
I have been googling a bit to decipher the codes on these. General info on these tubes labelled CV 1052
It looks like:
How about the printed values visible on the left tube? These look like "MO 2" and "39 C2". Both tubes have the same markings. Not sure how to date them from this? Also, what is the "6914 with the up arrow looking thing" visible on the right tube? All fascinating!
- CV = Valves used by the British military Armed Services were marked with a CV or "common valve" name which was defined by the Inter-Service Technical Valve Committee in 1941
- KB/DA (via this link)
- K = designates a valve manufactured to specification K1001 or K1006;
- B = denotes qualification by a UK authority
- DA = Mullard Radio Valve Co., Blackburn
Happy listening all.
The top row of characters: M0 = EL32 and 2 = revision code.
When a tube was first introduced, the revision code was "0". So in this case, "2" indicates that this was the second major revision.
And yes, as Mordy points out, "39C2" is actually "B9C2".
