mordy
- Aug 8, 2010
The most likely manufacturer is Sylvania.Anyone have an idea as to who made these?
How ironic! Another (upcoming) Glenn amp owner also in Seattle (correct me if I'm wrong). I would be interested to see how the sound of your GOTL compares to my upcoming GOTC (custom transformer-coupled SET OTL) amp. Curious when is the general timeframe for your amp?You know what the worst (and best) part of waiting for a Glenn amp is? Every month that goes by, I think, "hmm, maybe I want X upgrade too. Oooh, might as well get Y upgrade as well". So the longer I wait, the more expensive my GOTL is getting! It's gone from $1300, to $1500, to $1600, and now I'm debating whether or not I want to go full Yamamoto sockets. Send help.
Count me in for the USB cable tour, if possible. I'm not (yet) a believer in USB cable differences, but that must have been what I said about RCA cables a long time back, LOL. Are those also made / distributed by Lampizator?I'm very glad to read of your early impressions of the cable. Keep burning it in, things are going to continue to improve over the next hundred hours or so.
I may be able to organize a tour like i did with the Amber, but will need at least a couple of weeks before I'm ready for that as we're trying to keep up with the holiday demand.
Thanks for the interest, guys!
Fred
No. Theyre made by Final Touch Audio, though many Lampi owners use it,and I can hear why.Count me in for the USB cable tour, if possible. I'm not (yet) a believer in USB cable differences, but that must have been what I said about RCA cables a long time back, LOL. Are those also made / distributed by Lampizator?
Also a burning question I've had about the Amber 3. Which DAC chip does it use, and are there multiples in parallel? And how would one characterize the sound vs. An R2R DAC? Because that has been my ideal preference for an analogue lifelike sound - but it still needs to do rhythm / PRaT well. A little off-topic so feel free to quote me on the appropriate thread for it.
I was told around Christmas time for my amp. @2359glenn that would be cool to know how the general timeframe is lookin'? (Feel free to reply by PM instead). Sooner is better but take care of yourself first.
The best Mullards cost an arm and a leg. The RCA are great though. See if you can find the late 40's with D getter and long black plates. These should compliment the Tele's quite nicely. The RCA are definitely on the warmer side. I consider 1960's Mullards also to be on the warmer side. The mid-1950's (the "arm and a leg ones") I find more neutral/revealing with only a hint of warmth. Early Valvo and Amperex are also meant to be very good, but again earliest = "arm and a leg". Brent Jessee gives a great description of these tubes and variations on his site.
http://www.audiotubes.com/12ax7.htm
I have some RCA 5751 triple mica, long black plate arriving next week. 5 pack NOS/NIB with RCA 5 pack holder from another guy in Canada. From Brent's site:
"5751: This version was usually the one made for the US military. These have a lower gain than the 12AX7, but are otherwise totally compatible. Great hi-fi tubes, as the lower gain reduces noise and microphonics. These are all ruggedized and most can withstand a drop on the floor. The internal triode elements are matched as well. The early versions are more sought after as they usually have extra support rods and an extra mica spacer on top of the plate structure ("Triple Mica"), as well as blackplates, all said to contribute to low microphonics. Don't overlook the greyplate versions, they are also excellent tubes, and many of these have the triple mica as well. The GE non-military version is usually the "five star" series, intended for broadcast use. The RCA broadcast type is the "Command" series. Both the RCA and GE broadcast types are scarce, as are any of the triple mica types."
I also run the Raytheon 5751 windmill getter in the line stage of my preamp, which I like a lot. Not exactly "cheap", but about half the price of some of the other so called "top tier" European tubes.
I run 1960's Telefunken 12ax7 in the phono stage.
As you can see from above, the 12ax7 tube rabbit hole is about the deepest tube rabbit hole out there
Just so you know Keenan,im highly impressed! Well done!Finally got rid of those annoying XLR inputs, switched them out for some very nice RCA jacks today. I replaced the entire back panel, IEC inlet, cut new holes for the mutlivolt switch, RCA jacks, along with new tapped screw holes for the filament rectifier (was happy to redo this since I made a cosmetic mistake last time). Overall, a great success! Not a dramatic change in sound obviously, but it looks nice and I don't have to use XLR to RCA adapters!
That seems interesting. Why are you setting up to externally heat tubes with the GOTL - just to reduce transformer temperature, or to try special or larger combinations that were not otherwise possible?6 pack of GAS7G/6080:
I bought the Triad 20 amp 6.3 volt transformer (again) and am awaiting parts needed to make a wooden box that will be the same depth as the GOTL. Going to "dock" the box to the right of the GOTL and power the 6x power tube heaters via the external transformer. Have it jerry-rigged now to heat 2x power tubes and have been enjoying 4x 6080 and 2x GEC 6AS7G ( generously on loan to me from @GDuss ).
4 more socket savers that bring pins 7/8 out to externally heat the tubes have been ordered from Mrs Xu (she gave me a great price on 4):
https://www.ebay.com/itm/191741357847
I love what I am getting! The lows and lower mids are tremendously intimate. The photo shows a TS 12SN7 mouse ears driver. I have since switched to the 75+ year old NOS 12J5 Tung Sol's and the intimacy is extended through the mids. Better separation, wider sound stage, too.
I have "Pipe Organ" bass - like it is vibrating the floor and chair I am sitting in. This is an illusion, of course, but man...it is FUN!
When I get the box made and am powering all 6 power tube heaters externally, an added benefit will be the GOTL running very cool since it won't need to provide the amperage to the power tube heaters.
Hi LG,Finally got rid of those annoying XLR inputs, switched them out for some very nice RCA jacks today. I replaced the entire back panel, IEC inlet, cut new holes for the mutlivolt switch, RCA jacks, along with new tapped screw holes for the filament rectifier (was happy to redo this since I made a cosmetic mistake last time). Overall, a great success! Not a dramatic change in sound obviously, but it looks nice and I don't have to use XLR to RCA adapters!
