JKDJedi
With just one tube yes, and with both yes, just was expecting the output to get somewhat louder or comparable to one 6as7g tube, jot the case with the dual setup.Does the amp work with the 6AS7 tube in it??
Well I got the two Telefunken MH4 tubes today and kind of upset.
The box was to pristine it was a new reproduction box.
The tube is perfect old tube but it has nothing on it no writing at all not even the tube number.
How do I know if it is really a Telefunken? on the bottom of the base both tubes have a number 2 and under it is FL.
Does anyone know what these letters mean?
I have two General Electric 6BL7GTA (1959) and an adapter (two to one) that I'd like to give away or at least get any offers for, I've just had a fiasco of problems getting the right adapter for my Darkvoice amp (from China, from Bulgaria...nothing works ) and am throwing in the towel on this project/experiment, please take this thing away from me! I'm sure the adapter was wired for a parallel wired amp as it does not work well on mine (In series wired) PM me
Output tube is the 6as7g? And because of the design of the Darkvoice even if I had 8 tubes with adapter the gain will be the same, interesting.That adapter was undoubtedly made by @Deyan , he might be able to help you out or get you a working replacement.
Edit: oh I see, the adapter works but you were hoping for more gain. The Darkvoice is a cathode follower, so the output tubes are wired for unity gain, meaning any output tube will essentially have no gain, doesn't matter which one you use, won't get louder.
Nothing. Especially this:
Thank the Gods! My prayers have been answered.
Bravo @gibosi, first theoretical offering I've heard that comes closer to reality. At least the reality that some of us experience.
Have to applaud you for your clarity of thought and diligent work.
Also for daring to go where few would go. LOL, I have heard stories that in darker times, people were burned alive in the public square for suggesting that the Earth orbited around the Sun, or the Earth was round, or rectifier tubes had their own unique sound. I know, hard to believe, but it's true. Well, maybe not for rectifier heresy, we know rectifier tubes did not exist at that time...
But in fact, and ironically, the people doing the burning were called 'The Rectifiers.'
The Scientific Method is alive and well, the inquiry is open and active, the Unified Rectifier Theory is within reach.
Seriously, gibosi, thanks. Well done. Appreciate this information and all the tube information you continuously contribute to the thread.
I think my upcoming Glenn 6EL3N is better! <mic drop>
(BTW, I think that will be its final name)
Glenn, was doing some digging on this. I think they are made by Philips in Eindhoven, Holland. Here is one that looks identical, it is an E424, which was a Philips tube, a REN904 equivalent. Same code on the bottom 2 FL. I don't think they are Telefunkens, looks like that seller had some bad info...
Still gorgeous tubes though.
https://www.ebay.com/itm/Philips-E4...Audio-Tube-Valve-Rohre-Amplifier/253958550653
Thanks for the info.
I got screwed as usual when I buy expensive tubes.
This guy is selling fakes by putting them in reproduced Telefunken boxes.
I am sure they are good tubes but not what I thought I was buying.
One thing interesting about this tube is they have a built in capacitor between the plate and cathode.
Probably to stop oscillations, It is made of two plates lined up with each other one attached to the plate and one attached to the cathode interesting.
