UntilThen
- Jun 16, 2015
Cool. So Super 12 would also have the tube rectifier then.
Anything is possible ! Glenn will have to find you a very big case. As big as your 300b amp case.
I will have an tube amp in the foreseeable future. Since I cancel the DNA Stratus, it could be a GEL3N or a 300b amp. All in good time because mountain and water is keeping me entertained big time right now.
Hey Matt, what's the story with the stratus? I thought it would be ready by June?
I cancelled it after I met Miss Sansui.
So now I am a bachelor again in the hunt for another tube amp.
@Sound Trooper did you invest in a pair of speakers for your GEL3N? I think you have the only GEL3N with speakers output.
I discovered the joy of near field listening. Now these speakers and my headphones are getting equal listening time. So I need a tube amp that will drive both speakers and headphones. I know both GEL3N and Glenn 300b amp are up to the task. For near field listening, I don't need it to be very loud. At 1 to 1.5m away from the speakers, you don't want to blast it.
Woah.. vintage amps are that good? I've not seriously looked into them yet.
Not too sure if I have the only GEL3N with speaker outs? Maybe @2359glenn has built other GEL3N with speaker terminals. I initially wanted to run a pair of Omega SAM with the GEL3N but I got.distracted and I ended up upgrading my DAC and adding the Blu MkII. My plan is still to run high efficiency speakers out of the GEL3N so either the a pair of Omega SAM or Voxativ zeth.
Yes you have the only EL3N amp with Speaker outputs.
I listened to your amp for awhile 2 days on speakers sounds really good and goes surprisingly loud for 1.5 watts.
Was asked to lower it. Was really plenty of power for me most of the time.
It is the sound of the EL3N amp that I love.
If I ever get time plan on replacing The 300B amps with EL3N amps.
Much prefer output tubes that cost $15 over tubes that cost $1500 and they sound as good or better to me.
I think that Glenn mentioned that he worked for Harman Kardon.Haha! I can wait until you 'discover' vintage Harman Kardon amps!!! The Tube amp forum will never be the same
There is no doubt in my mind, based on listening to both, that that certain 6N7GT (VSX, NU) tubes sound better than the FDD20.It will work, I do find Visseaux 6N7 sounded a little better than FDD20
