Xcalibur255
- Feb 4, 2008
Unfortunately you have found the downside to having a setup that uses a large number of tubes. Getting everything quiet is a patient process of trial and error. I might suggest gently (very gently ) tapping each one of your tubes with a wooden pencil with your headphones on (and the amp powered up) to see what kind of microphonics/noise each is emitting. The major offenders will become obvious pretty quickly.
This is why I basically stopped tube rolling. It stopped being fun and started becoming stress. Once you find a combination you like that works just set the cruise control and leave it in the amp. It will be years before you actually need to replace them because they are worn out (unless you use your amp all day every day).
I'm not very popular around here for stating that having a gazillion tube rolling options is a double-edged sword, but so far I've seen several people buy and then sell their amp because they were intimidated by the amount of choices or were stressed out about finding the "perfect" combo. I can't be completely talking out my ass if it's causing people to walk away.......
I think the original configuration of this amp is still a great sweet spot and highlights the strengths of the KISS ideology. 3DG4 for the rectifier, no need to mess around with anything else there. You can basically start and end with the Brimar 13D1 for a driver for 90% of headphones and music genres. Track down a quiet pair of 6520s for outputs and voila you have a great sounding amp that works well with a variety of headphones. If the 6520 is proving hard to find then any 6AS7 type that isn't noisy is not going to do you wrong at the end of the day.
