Drivers and power tubes in GOTL
Alright
@Althalus I'll explain one more time for you or for anyone who needs to know. If you forget, just search for those words in bold in this thread or you are going to remember post #20903.
For illustration I'll post this picture again. For those OTL with tube rectification, there will be another socket to the front left.
Looking from the front of the amp to the back...
. 1st socket - this is for 6sn7 / 12sn7 / 25sn7
. 2nd & 3rd sockets - strictly for c3g (have to use in pairs)
. 4th & 5th sockets - 1st pair of power tubes
. 6th & 7th sockets - 2nd pair of power tubes
. 8th & 9th sockets - 3rd pair of power tubes
Now what to use in those sockets:-
( None of these need any adapters but you can optionally use socket savers to preserve the sockets )
1st socket:- 6sn7 / 12sn7 / 25sn7
. 6sn7 - 6sn7gt, 6sn7gta, 6sn7gtb ( set switch to 6.3 volts)
. 12sn7 - 12sn7gt, 12SL7gt, B36 (set switch to 12.6 volts)
. 25sn7 - 13D1, 1633 (set switch to 25.2 volts)
2nd & 3rd sockets - c3g (any brand)
4th to 9th sockets are strictly for power tubes. So what power tubes can you use?
(one of the combinations below)
. 6 x 6BX7gt or 6BL7gt / gta (use either 6BX7 or 6BL7 any brand - don't mix the type but you can mix brands - these go in 4th to 9th sockets)
. 2 x 6336, 6336a, 6336b (brands can be Tung Sol, Chatham, RCA, Raytheon or Cetron - can ONLY use one pair of these tubes - they can go into either 4th & 5th sockets or 6th & 7th sockets or 8th & 9th sockets)
. 2 x 6as7 or 6080 (they can go into either 4th & 5th sockets or 6th & 7th sockets or 8th & 9th sockets)
. 4 x 6as7 or 6080 (these go into either 1st, 2nd or 3rd power tube slots)
. 2 x Tung Sol 5998 or 7236 (same as per 2 x 6as7 or 6080)
. 4 x Tung Sol 5998 or 7236 (same as per 4 x 6as7 or 6080)
*NOTE:- All these are for the most common type of tubes used in GOTL. Ones that are special and that needs adapters will be addressed separately.
