2359glenn | studio
- Thread starter Silent One
whirlwind
Hi Sam
You will be supprised how good speakers sound on this little amp.
I did forget to put the HEXFRED in the box I will send that next week.
Here is a pic of the underside of your amp.
Very nice Glenn...wish I could solder that well
![Beer Chug :beerchug: :beerchug:](https://cdn.head-fi.org/e/headfi/beerchug.gif)
2359glenn
Member of the Trade
- Aug 16, 2010
Thanks Glenn, looks absolutely stunning!
The hardest part building this amp was wiring the 8 ohm 32 ohm switch 16 wires from each output transformer.
Are the functions of the 3 knobs at the front Volume, Input Selector and Headphones/Speakers selector?Day 2 with the EL3N
I have about close to 20 hours on the amp now and I couldn’t be happier. The amp is dead silent and the chassis doesn’t feel hot. In fact, my audio-gd feels warmer to touch than the EL3N.
Da bass, it’s to die for. It’s very controlled and has a nice texture to it. So far, I feel the LCD-2 pairs very well with the EL3N and the bass on the Abyss gained another dimension as compared to the NFB1. The EL3N has plenty of power in 2 tube mode and drives the Abyss with authority. Another observation, the EL3N is really clean sounding. It sounds more like a big solid state amp than a tube amp.
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
The left knob is for impedance (8 & 32ohms)
Center knob is for volume
Right knob is for single and 2 tube mode
I’ll start to look around for speakers soon!
UntilThen
- Jun 16, 2015
The GEL3N has a lot of grunt if it can drive the Abyss with authority. I have to crank up the volume on my Ragnarok with the Abyss.
This neutral and transparent sounding amp is totally different from what I heard on Elise with the self improvised 6 x EL3N - which is warm and lush.
Hi UT, let me know when you pass thru. You are welcome to come for a listen.
UntilThen
- Jun 16, 2015
Thanks. Looking forward to listening to it.
Let me know how it sounds when you do hook up a pair of speakers to it.
UntilThen
- Jun 16, 2015
Glenn, do you have a picture of my amp bottom? ![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
whirlwind
It’s time for the LCD-2F to have some EL3N magic..
Great gear!
gibosi
- Oct 18, 2012
Yes we both have the TS 12sn7gt black glass round plate but my numbering is not visible anymore. If it's 1948 that's a pretty old tube.
Mine is under going the mandatory cleaning and gold Deoxit before using it.![]()
And there are three versions of this tube, one with a round mica spacer, one with an oval mica spacer and metal springs, and the third, with flat plates and square mica, like the similar 6F8G. I believe that the version with the round mica spacer was the latest.
![2018-05-05 10.07.57.jpg 2018-05-05 10.07.57.jpg](https://cdn.head-fi.org/a/10109085_thumb.jpg)
![2018-05-05 09.54.15.jpg 2018-05-05 09.54.15.jpg](https://cdn.head-fi.org/a/10109086_thumb.jpg)
JazzVinyl
- Jan 7, 2010
Great info, Gibosi....
Mine appears to have the oval mica:
![image.jpeg image.jpeg](https://cdn.head-fi.org/a/10109097_thumb.jpeg)
whirlwind
6 and 12 volt versions here....both are oval mica
My 6F8G tubes have the same oval mica also
Great pics as always gibosi.
Total: 15 (members: 0, guests: 15)
