UntilThen
- Jun 16, 2015
12au7 adapter arrived today. Let's see what the Mullard cv4003 can do.
More to the point, time to get in line.
I love this hobby. The ability to tune your gear with a change of tube types or brand is just amazing. I would never have known that 12au7 would work so well in Glenn OTL until I tried it.
Can you post some pics? I'd like to see the difference between the SS rectifier and tube rectifier versions.I have to say that bass on HD800 is on another level with my Glenn OTL. Listening with GZ37 fat bottle, ECC32, 6 x Fivre 6BX7. This is what these headphones are really capable of.
Do I need to buy an adapter for the 12au7 to work in the GOTL,and how many of this type of tubes does it need ? Im particulary fond of my Telefunken,and most likely would want to pair it with something with some warmth.
Ros what configuration did you have on your GEL3N ?
Did you have the better sockets? Did you have special caps?
Multiple input jacks?
With this adapter, you can try both 12au7 and 12ax7, the latter has a much higher gain but JV finds it works with a pair of 6as7.
Telefunken 12au7 is another good brand but I think the tone is more clinical whilst the Mullard is more lush. However I would have to listen to know for sure.
In addition to as 12A-7 types, you can also roll E80CC / 6085. These were manufactured in Holland by Philips and in Hungary by Tungsram. Good sounding tubes.
