rnros
- Sep 12, 2004
You guys are killing me with the pics, lol.
I do have a question to owners of the EL3N tube amp. How does it handle low impedance and high impedance headphones? I’m looking for an amp to drive the Auteurs, HD650, as well as the Aeon Open Flow, and E-Mu Teaks which the latter two are low impedance cans.
My thought is if the Auteurs eclipse the Aeon Flow Open then I’ll sell them and purchase the GOTL. If not then possibly buying the GEL3N instead to be able to run low and high impedance headphones. Thanks in advance for any advice.
Can't answer your first question, but I can tell you that the GOTL pairs well with the Aeon Closed. That's an understatement, I think it is outstanding with the GOTL. Also drives my other low impedance headphones without issue.
I know the conventional wisdom, OTL for high impedance only, but it does not apply here. It may also apply less often going forward since low impedance does not necessarily mean low efficiency anymore. And, seriously, GOTL can use six 6BX7s! Or, better still, two Cetron 6336Bs. Astonishing power, and control.
I have high expectation for the GEL3N and look forward to hearing it for myself, but IMHO, I would not overlook the GOTL. Guessing you have already researched the differences between OTL and trasformer coupled, so you know the unique qualities and advantages of each.
So either way, good choice.
