UntilThen
- Jun 16, 2015
Know what you mean about the "incisive tone" of 6BL/BX7's...faster/sharper/more dynamic.
Spot on JV.
Some years ago when I used 5U4 rectifier in 300B amps. It was powering two 300Bs and two C3gs that add up to 200ma
at twice the voltage used in the OTL 425 volt or 850 PIV. Someone put in a GZ32 and it violently exploded on the inside.
I only recommend using this tube in the EL3N amp.
Too bad. Matt, do you wanna to try it on your new toy?
That will generate spikes when u turn on the amp. and shorten the life span of your valuable tubes too. So just leave your amp on all the time. LOLThis new Scar Jo will protected and loved. There will be no violent explosions. No thank you. This is why I chose the safe option - hexfred.
I like on the OTL amps with the PY500/42EC4 rectifier tubes , that one will lite up a bit before the other then the second one starts to light...
And I thought it was Lake Moraine...Lake Louise, Alberta, Canada is the picture from Andrew Larsen.
sample some drivers on GOTL. Power tubes are 6 x 6BX7.
These are the top contenders for best drivers from my collection:-
Siemens C3G (more microphonic than the others)
Sylvania 6sn7w metal base
Tung Sol 6F8G black round plates
Mullard ECC31
GEC B36
Marconi B36 metal base
GEC B36 brown base or Sylvania 6sn7w metal base? I've to toss a coin on that one.
2 very different sonic presentation. 6sn7w is fast, dynamic, precise and ultra revealing. Wide stage and good bass impact. GEC B36 is on the romantic side of the spectrum. It's not overly warm and lush. Not to my ears. It's a great tone. So soothing and smooth.
I've to thank Stavros once again for the GEC B36. It's NOS and came in a pristine GEC box. Can't believe he sold me this jewel.
