Can users please tell me what types of 6BL7 tube are better than others?
Did you mean 6BL7s or 6BX7s? Both good, I think most prefer the BX7s. On the BX7s, I have/use Sylvania, GE, and RCA. I typically use 4 Sylvania and 2 GE or RCA.
With my BX7s, I actually selected tubes/pairs for lack of noise, so that's why the mix of brands. I may purchase more, they are very good
Don't remember which BL7s I have, haven't used them for a while.
And another one - 5V rectifiers - advice please as to best ones to start out with beyond HEXFRED plug-in.
Some that I have tried:
Good and low cost ($5 TO $20): 5CU4, 5AW4, and 5C3S (Soviet/Svetlana). I went with Glenn's recommendations, I think he recommended all of these.
At higher cost, and very good, Mullard GZ37, available at Langrex, about $110. Also recommended by Glenn.
Adapter req'd: GE 1641/RK60, Very good/excellent tube at reasonable cost, about $40.
(The only adapter I found for this tube is prone to very slight vibration, solve that problem and the 1641 competes with the UE596.)
Adapter req'd: UE 596, Excellent tube, higher cost, and (very) difficult to find, about $150.
I rotate all of these from time to time, 5CU4 probably my favorite in the low cost category. The 1641/RK60 usually stays in the amp unless I'm rolling another tube.
These are all good, so depends on your ear, power tubes and headphones.
There are many others, I'm sure others will provide options, and you can search the thread also.
