UntilThen
- Jun 16, 2015
Glenn's use of a single 6SN7 and equivalent is a big advantage here. It sounds as good as those amps that use 2 drivers and when you're buying expensive tubes, your wallet will thank you for buying just one tube.
Tube rolling on GOTL applies to all headphones. Adapter for ECC31 has just arrived. After warming up ECC31 and 6 x 6bx7 for 2 hours, I started listening with HD800. I can't believe what I hear. ECC31 has a romantic tone with a voluptuous bass. Coupled that with the tight, punchy tone of sextet 6bx7 and the result is pure euphony.
Very nice! Are the E-bay Chinese made tube adapters best avoided?
I have Hexfred. What is the advantage of each option?
The mercurial pairing.
Nice and very nice image.
Are you using solid state rectifiers?
Thanks, so GOTL is good with low Z cans as well. Are there more preferable tube combinations that work better with low Z compared to high Z? I'm thinking 42 ohm dynamic, but not a hard to drive planar or anything like that.
Funny, I had my pair of ECC31's in the Elise this AM and yes..."romantic" is a good description for them. Add the BX7's...and I am certain you have a really nice sounding amp!
Have you tried FDD20 as driver?
Nice collection of headphones and amps rnrros.
At the beginning of last year, I wanted to get Schiit Gungnir Multibit and Mjolnir 2. When I went to Addicted To Audio, that plan went out the window and I had to redraw my plans and my cheque. So I end up with Yggdrasil and Ragnarok (together with Euforia) and I thought I will live happily thereafter. It was the most gorgeous sound for a while. Then in the midst of my total contentment, Glenn pop into my thread and said hello. That changed the course of my audio history. Now Euforia is sold and Ragnarok sits on the floor - unplugged. There's no space for it on the desk or the rack !!!
