- Aug 2, 2014
Hans I worry for you. Your life will be changed now.
Oh, it’s WAAAAY to late for me man.
The only tool missing is a powerful enough hammer. LOLI have a new set of Stanley screw drivers. I'm all ready to learn.
First lesson would be to change the USB 5 board for Yggdrasil early next year. There's a lot of screws in that box !!!
Really? You believe the high-end 6as7g tubes beat 6bx7 / 6bl7 ? Right after I've invested in twenty-four 6B*7 tubes??? Are you trying to lower the worth of my investment?
Hi 2359glenn,
Way back I remember that you said that the 6 pack 6BL7/6BX7 sounded better than any 6AS7 type tube in your amp. Have the new models changed that?
There is a cool looking driver that you can use too. It's the FDD20. A nice blue looking tube. Need to get the FDD20 to 12SN7 adapter.
But if one is going to go down that road, then 2.5 volt Arcturus 127 triodes are even cooler:
I comparing the 5998 and 6BL7 i was close. With the HD-800s 300 ohm phones the 6BL7 seemed a little better
but a close call. With the price difference the 6BL7 wins I just bought 6BL7s for $4 so $24 for 6 of them is a bargain
compared to over priced 5998s.
I didn't try with low impedance phones no time have to put the bottom on Matt's amp to box it up tomorrow.
The only reason to use 5998s would be to put 4 of them in to drive certain low impedance phones.
But I would try with one pair first not to burn 4 expensive tubes if not needed.
And the better option would to use two 6336 with low impedance phones but the 5998 sound better I think.
After listening to different tubes all day who knows what sounds better at this point.
Many thanks! I thought you needed a special switch to bias 5998 and 6336? Perhaps I misunderstood about the 5998.
I saw the comments about 6BL7 and 6BX7s above, so I was definitely curious about those. I love the GEC 6080s - really nice staging and transparency, just wondering what else is out there after being blown away by a $10 RCA 5U4GB recently. Got me curious about other budget gems!
That's so cool. 2.5v so can I set the switch to 6.3 volt for it? Also there are no known adapters for it.
And with a adapter you can use two EL3N tubes in the 6SN7 socket.
And don't forget the 7N7 with a adapter.
