Pah! <kicks sand in the face of EL3N amp>
Then again, practicality is an issue with the 300B. It throws a lot of heat, gets quite hot, weighs more than most mothers-in-law and nice 300B tubes are crazy crazy expensive.
Ha ha.
If one needs 8 amps then the 300B is the way to go, no doubt about it.
No doubt about it that it is the better amp.
That being said, the EL3N amp has much going for it....it will power most headphones out there, with some exceptions as you say.
$20 each for the sound of these tubes is an absolute bargain, the amp runs so cool it is not funny, chassis is
never more than luke warm...only heat from the amp comes from rectifier.
Two different modes to listen to, with one of them having nothing in the signal path...this mode will be dead silent, even if you do not have the quietest tubes.
My planars are at ear bleeding levels with my amp in two tube mode and volume pot at 10:00.
The ZMF Ori is not a hard to drive planar, I don't feel I am missing anything...the sound is big and the synergy is a 10/10.
I have not listened to my HD800 very much since I have had this amp.
The bang for the buck is off the hook with this amp......granted, it may have it's limitations, but you need to know what you want it for before buying.
The EL3N tubes can be finicky, I bought quite a few to make three solid sets that I like, but at $20 each at least it is not like paying $100 or more for a tube to find it not to your liking.
You only need the front two tubes to be quiet as if you have any finicky ones, you can throw them in the back two sockets and they are just fine.
Matt, you must be very excited to see that pic
