lukeap69
- Feb 15, 2014
Yes, recessed socket works with some custom cables but not all. BTG Audio and PlusSound make pretty good cables for recessed. I did not choose the recessed socket just because it is easier to find some cheaper Chinese aftermarket cables with Westone 2 pins equal or better quality
Thanks ericr, ive been looking for a reason not to look at the k10s due to its price. Oh well...
Thanks for the input. I'm gonna have to think about whether i want to shell out the extra 150 because at 550 dollars the qi is already stretching my budget. Would you say that the v-6 stage is around as bassy as the qi? I really love good sub bass and a slight mid bass hump.
Any insight into a custom cable that would compliment the v6?
Mrmax,
Is there any opportunity to demo the Qi in Manila?
CenterDrive™, a more advanced balanced armature design where the “drive shaft” is attached to the center of the diaphragm. The result is a richer, deeper and more effortless bass reproduction.
Yay, so excited. I should have my V6 by tomorrow
