- Oct 6, 2013
I'm upgrading from U12 to A18. I will miss ADEL and my MAM. I think APEX will suit me fine as I never listen at high volume. I'm in need of a better fit from the customs and I think that will outweigh the benefits of the MAM for me. Anyone else in a similar situation?
I went the other way, from Customs to Universals, though it was due to my left ear anatomy where I have a sharp bend which makes fit uncomfortable. Also, it wasn't comfortable whenever allergies are acting out. I'm actually able to get a very good seal with U12 using silicone tips.
Btw, why did you decide to upgrade to A18 instead of TIA Fourte? Unless TIA is offered only in universal? As you have probably seen in WCDchee reply here, he mentioned that if you like U12 sound then U18 will not be your cup of tea since it's tuned differently. Per his comment, in terms of a sound, U/A18 is an upgrade from U10.
