ButtUglyJeff
- Apr 3, 2011
I'd just blow that money on liquor and cigars....
Hey @Stillhart - great stuff you are posting. Thank you.
I haven't seen you comment on this, though perhaps I've missed it - it's hard to keep up. LOL
Can I ask what your thoughts are on the Uber Bifrost paired with the LC?
Thanks.
I've actually never heard the Uberfrost. @Evshrug has one that I might be able to borrow at some point, haven't heard it yet.
Still, it's got a pretty stellar reputation. If you like the Schiit house sound, it's certainly one of the more obvious choices of a small DAC in a similar price range to the LC.
Thanks. Really appreciate it.
I'm thinking about upgrading so I can use the Uberfrost bedside. Could spend up to the amount of the Yggy. But I'm lost as to what would be the best. It's not that I'm sold on Schiit (though they have been good to work with), just want to get the best bang for the buck.
Then one day I would like to go to one of the higher end Cavalli amps and want the DAC to work wonderfully with it and my LCD-X. Thoughts?
I'm excited to get my feet wet with the LC on my journey towards audio nirvana.
My honest advice? Spend some of that money on a flight to CO and hit up Canjam next month. Go listen to a bunch of gear and decide for yourself what sounds good. Nobody can tell you what will sound good to you but you.
Thanks. By the way, how tall are the included rubber feet?
Hey gents, the production amps won't have rubber feet. They will have small semi-circle protrusions that run the length of the amp front to back. There will be two of these. It takes time to stick on feet and they frequently come off.
- Violectric V200 (does it sound vaginal?)
The moral of the story: phase splitter isn't as almighty as I made it out to be, but it's still good.
Aww, Sensei @warrenpchi would be so proud of me right now!
Great advice. And I wish it was something easy to do. I live in Central America.
Is California easier? We're only days away from announcing anyway, but if you promise to keep it in this thread and no further until this coming Saturday...
@Stillhart
am I mistaken, or does your evidence of the GMB single ended vs the Dac-19 single ended vs the Theta balanced vs single ended vs the GMB balanced vs single ended really point out that the SE implimentation on the GMB is the weakest of the above, and not so much that the phase splitter on the LC is not so great?
I'm not trying to be cheeky or to bash the SE implimentation on the GMB, but unless I missed something, all the "good" SE implimentations above (Theta SE, Dac-19) went through the phase splitter, along with the "less good" implimentation above, the GMB SE? The other "good" implimentations were of course the balanced Theta and GMB.
This just seems to show:
1) that not all dac implimentations/circuits/outputs are created equal
2) The phase splitter is probably just fine
3) The balanced output is the preferred output for the GMB
Or did I missinterpret or just plaiin miss something?
Ignorance IS bliss.......
I'm probably better finding a reasonable consensus
On that note, I am continually surprised at the feedback on the LC so far. Hundreds have auditioned under meet conditions, about a dozen have auditioned under loan conditions, and not a single negative impression so far. That's pretty darned impressive.
