- Mar 5, 2012
We've been using this with good results.
http://amzn.to/2mp3E7f
I just tried it tonight. It definitely DOES NOT work for me. I get the same problem that you do--it pulls power from WA8 to the Omnicharge, instead of vice versa. Quite the bummer, considering I got the Omnicharge solely to power the WA8. Looks like I gotta bring the huge power brick with me, as well as the Omnicharge, as well as the WA8 in order to enjoy it on a cross-country flight.
EDIT:got it to work! Needed to fiddle with the menus a bit and now it works. It will show an "AV" icon when it starts to work.
What he said. I had a lengthy conversation with OmniCharge support with this too. It seems when the WA8 battery is flat it initially draws more than than 3.5A which is above the OmniCharge's DC output function and that tricks the OmniCharge into thinking that you're charging the OmiCharge instead.
If you plug the WA8 before it goes flat, then the OmniCharge will work as you desire - to charge/top up the WA8 battery.
I suspect the Omni charge will really work reliably for the WA8 when the WA8 is turned off, maybe not so much when the WA8 is on and needing extra power and having too depleted of a battery. I hope to have some time to experiment with mine this weekend.
TRY THIS with your tube amp! Just relaxing with my WA8 & Ether Flow, nothing better than ocean waves as ambient background.
We look forward to your findings after 150–200 hrs. of initial break-in. Be sure to post some pics.
Just wondering, is the DAC on the WA8 USB bus-powered?
So what headphones are you WA8 owners running these days? The PS1k and ZMF Ori both pair wonderfully without any sense of being underpowered.
