jkteddy77
- Jan 18, 2015
I ran into same pita situation when my meelec m6 and tf10 played games on me.....I gave up on M6 and bought a new fiio cable for the tf10.
I suspect a short @ y split. W/o soldering the cable ends with the 3.5mm jack,what do you get when testing these 4 ends between them using mm.
I just get a reading between the right channel/right section of the plug and with either of the grounds. I'm assuming the grounds are continuous, both show the same reading when i test them with the ground, but the right channel should not be continuous with them.
Like I said, the left channel is working fine, but the right channel outputs to both the left and right, and that seems very odd to me. I was thinking a short in the y-split or somewhere along the line there, but both channels worked fine just before I cut off the old plug, so it doesn't make much sense to me.
