Got the Shakes
I believe that moving your head is exactly how it works. The realiser uses the angle calculation of the headband sensor to work out when you are at the correct angle and then outputs the sweep when you are in place. Never having done a PRIR measurement I am not exactly confident of my understanding but Smyth himself has indicated that a satisfactory measurement can be taken with a single tweeter so you may be better off ignoring the actual setup in your room. Just guessing though.
Makes sense. I knew that they had mentioned the ability to take measurements with a single tweeter, just wasn't able to find much documentation on the A16 setup at this point. Thanks again for your quick response. Now to figure out what my potential headphone upgrade once I get an A16 might be...
