Hello Guys, I have been using vantam R627 mkii for a long time and a tragedy happened. My micro usb plug was torn down and now I cannot use the micro usb to transmit DSD signal, however, other input are normally functioned. Do you guys know that how can I repair it or just leave it alone?
Introducing VentureCraft SounDroid VALOQ [SDP-1]-Impression thread- Check second post for updates
- Thread starter audionewbi
If still under warranty you can bring it to the distributor for repair... or you can repair yourself if you have good soldering skills..., where are you based?
I am from Hong Kong, and the warranty is over. Also, I bought this product in Japan last year, so the local distributor are unwilling to fix my product
DrSheep
- Nov 17, 2012
Is this directly from VC HK? If not, PM me for some contact info.
VCMan
- Oct 10, 2010
6 months have passed since previous FW update was issued...
No hope for a new one?...
DrSheep
- Nov 17, 2012
Why? Most of the major and even minor issues had already been resolved.
VCMan
- Oct 10, 2010
Two issues left:
- the screen turns on every time you touch volume control knob
- no "carousel" scrolling yet (not sure it's called that way - I mean when you scroll to the end and want to return to the top, you should scroll all the list backwards again).
When/if these issues are solved, Valoq woul be a perfect device (for me, at least)
DrSheep
- Nov 17, 2012
But those are more of design choices than bugs.
VCMan
- Oct 10, 2010
Sure, these are not bugs.
But IMHO, the purpose of upgrading FW is not only in removing bugs, but in... errr... upgrade as well, is it?
deafdoorknob
perhaps silly questions but i don't think they're covered within the thread (if they are, apologies):
1) can it be used to accept stream from iDevices (with CCK) as a USB DAC - for my spotify and TIDAL needs
2) is gapless playback true gapless now?
3) if I don't intend to op amp roll, should I opt for something else?
4) in stock form, is it quiet enough for super sensitive IEMs (CA andromeda, fitear etc)
5) if the answer is No in 4), which op amp would users here suggest for super sensitive IEMs
thanks in advance!
thanks in advance!
Valoq is a pretty dedicated purpose piece of kit. It does one thing and does it exceedingly well. I own the limited edition and had the chance to audition the Sony WM1Z. The limited edition Valoq surpassed the Sony in resolution and naturalness by a wide margin to my ears.
deafdoorknob
so, it's a player only device that can't be used as a DAC?
also, are you using it with high sensitivity iems? if so, is it hissy?
thanks
I have listened with high sensitivity IEMs without hiss.
VCMan
- Oct 10, 2010
No IEMs of mine (UM Mentor, Fostex TE100, Atomic Floyd Superdarts) are hissy with it.
VCMan
- Oct 10, 2010
A new FW is out: http://venturecraft.jp/gadget_jp/
Google translate from Japanese:
- - Enhanced ability to respond to mp3 files with illegal headers
- - Improvement of L/R inversion
