auricgoldfinger
How much of this sound difference would you attribute to using a micro-rendu with LPS, and how much to converting the ethernet to fiber? I found that just putting the last ethernet switch onto my regen and the rendu (and now a SOtM SMS-200) onto a LPS made an improvement in the noise floor. Have you compared before and after with the fiber conversion in place?
I have to say if the prices in that article are accurate its worth trying out, I'm just not getting my head around how introducing that conversion actually helps. The MC100CM with have some 'electrical noise' itself, why would that get into the rendu any less than noise from an Ethernet switch on good, regen'd power?
I would say roughly 65-70% of the improvement is a result of the microRendu and the balance is the ethernet to fiber conversion. Adding the LPS to the second MC100CM has a more subtle effect. For example, the zils on the tambourine have more depth and sparkle, and guitar strings have better separation and resonance. I wouldn't recommend spending a lot of money on a dedicated LPS just for a 10-15% improvement, but something inexpensive might be worthwhile. In my case, I had an available port on the JS-2, so there was no incremental cost. The reader comments in the original article that I linked have a couple of inexpensive suggestions. iFi Audio also makes a $50 product. I have no experience with any of them.
I'm not going pretend that I understand how it works. I suppose that there could be a type noise that the microRendu doesn't filter, perhaps due to frequency or wavelength. Possibly, the microRendu has a finite filtering capacity, and the ethernet to fiber conversion removes the overflow.
I take your point about the MC100CM being a noise source. I wondered about it myself before taking the plunge. All I can say is the noise from the MC100CM is negligible in comparison to what is removed upstream of it.
