auricgoldfinger
Everyone loves talking about their equipment and tubes. No one talks much about cables because they’re just not terribly sexy. That said, I’d like to mention the solid core silver interconnects that I just added between the Stratus and my DAC.
Recently, I spent a lot of time researching solid core silver wire for a DIY headphone cable project, and eventually, I stumbled upon VH Audio.
From the VH Audio site:
VH Audio's UniCrystal™ OCC (Ohno Continuous Cast) Silver wire is meticulously drawn through special dies, dead soft annealed in an inert nitrogen atmosphere, and follows special handling protocols to minimize any surface marring, before the insulation process begins. Our unique AirLok™ insulation is a proprietary form of foamed/cellular Fluoropolymer that achieves a dielectric constant of less than 1.45! By comparison, the dielectric constant of solid fluoropolymers, such as DuPont™PTFE, FEP, and PFA (referred to as Teflon®, when licensed from DuPont) is 2.1. A perfect vacuum is 1.0.
I asked how the lower dielectric constant manifests itself in terms of sound quality, and here was the reply:
“It’s faster, and more neutral. The lower the dielectric constant, the less dielectric involvement to color the sound. Also, the dissipation factor of the dielectric means the dielectric is less prone to ‘soak up’ signal, and re-release the energy.”
I noticed that VH Audio sells interconnects using that same wire. Furthermore, they offer a 60-day trial period with a 100% refund if not satisfied. I decided to take the risk-free opportunity to try their Pulsar Ag interconnect cables, which consist of ONE 24 AWG solid core silver wire. If the cable sounded good, I would plan to buy the same wire for my custom headphone cable.
I only listened to a few bars of Led Zeppelin in 96/24 before I was completely blown away by the sound. There is a dramatic improvement in transparency and openness, detail, imaging, and soundstage. Timbre is beautiful. Decay is outstanding.
I am using WBT NextGen RCA terminations, but there are less expensive options. If you’re interested, talk to Chris about the differences.
Those of you using SPDIF cables may want to consider having one made from this wire. I’m pretty confident you will like it.
