Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
- Thread starter Mython
WayTooCrazy
That's a lot of gear & cables for... earbuds
It is. They are Venture Electronic Zen 2.0 Black Edition, which are 320Ω. I would not try and get on the plane with this setup, lol.
AviP
- Dec 14, 2015
Does anyone know of an OTG adapter for an Android phone which would allow me to charge my phone while keeping it connected to the Mojo?
SomeGuyDude
- Jun 24, 2012
Quick Q y'all. I thought the Mojo auto-detected sampling bitrate, according to the manual, but mine doesn't seem to do that. It goes by whatever I have it set in Windows. Is there any way to have it go automatic?
Ike1985
- Oct 22, 2014
Did yo try changing to 2 channel OP here:
Yea, tried that. Didn't work. Oh well!
Ike1985
- Oct 22, 2014
I went down that path, found nothing. Suggest you try wireless charging if possible. FYI Startech makes excellent OTG cables at a cheap price.
Fully agree I use UAPP with my OnePlus 3 under Nougat. It works properly, with Meenova cable it pairs with Mojo.With UAPP the native android upsampling is disabled as UAPP uses their own driver. This is why I use UAPP, I don't want my music upsampled. I'm on S7E and UAPP performed flawlessly with both marshmallow and nougat.
The issue UAPP can not play Tidal Offline (only can stream) and that's a handicap for me.
I don't understand why UAPP can not play Tidal Offline meanwhile all specific android USB drivers of mid/high DAPs (FiiO X5, iBasso, etc.) can do it
@almarti I can check to see if X5iii to Mojo is working with the latest firmware in a few minutes. I don't have the EtherFlow... but I do have hard to drive earbuds (Venture Electronics Zen 2.0 Standard in Balanced form, as well as the "Black Edition" of the Zen 2.0 as well). I also have the Sennheiser HD6XX sitting next to me, and the X5iii does drive the HD6XX to loud levels, synergy is subjective though.
Update: Yes, X5iii to Mojo is working well through USB or Coaxial. The latest Firmware seems to have corrected the USB problem.
Though, I will admit... I rarely pair them, as I feel the X5iii is strong enough on it's own.
Nice photo. Thanks for the clarification, I had an HD600 so I can confirm then than Ether Flow will be very well driven.
Which cable are you using for coax connection?
Barndoor
I tried wireless charging. My LG G3 won't wirelessly charge if something is connected to the usb. Couldn't find any settings to change and asked here without anybody replying that they had succeeded.
AviP
- Dec 14, 2015
Thanks for your input. I have a G3 too, you saved me the cost of a wireless chargerI tried wireless charging. My LG G3 won't wirelessly charge if something is connected to the usb. Couldn't find any settings to change and asked here without anybody replying that they had succeeded.
- Apr 18, 2016
UAPP cannot save offline files because Tidal has not granted them a license to do so. Only the app from the app store can save songs offline; which is why the Fiio x5 III can do it.
fordski
Yup I had the same problem with my LG V10. Wireless charging doesn't work with anything plugged into the USB port.
WayTooCrazy
Thanks. The cable itself is DIY (quick and dirty to just "test" the Coax out), but the wire is Toxic Cables Viper.
I downloaded UAPP from the Play Store and paid for the license. So, then, has UAPP to pay more to Tidal as it is supposed FiiO has done to enable Tidal offline in its DAP line?UAPP cannot save offline files because Tidal has not granted them a license to do so. Only the app from the app store can save songs offline; which is why the Fiio x5 III can do it.
miketlse
- May 8, 2016
It is a standard way to monetize a technology.I downloaded UAPP from the Play Store and paid for the license. So, then, has UAPP to pay more to Tidal as it is supposed FiiO has done to enable Tidal offline in its DAP line?
Invent/patent a technology, and then charge customers for a licence to use the technology.
