peskypesky
Noodle cables ruleToo bad they used a noodle cable
Yes, it is. It can be a bit bright due to the beryllium drivers, but overall can't think of anything with over-the-ear ergonomic fit under 100. But if you ask me the vsd3s is almost the same with a hair more warmth and sweetness and a tad bigger bass at almost half the price.Hi,
are vsd5s still good option? Or is there something better over the ear under 100? I'm looking for something neutral (probably). I had Havi B3 till now.
+1try hds3, girth about 7mm and it just disappears in my ear lol.
the einsear are definitely warmer than the seafh, which are going for a crisper, more extended high end--if you're a treblehead the seafh will appeal to you more. personally, i rate the einsear a slight notch higher--they have more overall coherence and better bass control, whereas the midbass on the seafh can get a tad unruly/smeary. i'd give the einsear a bit more time, altho of course your own ears are ultimately all than matters.Just got my Seahf AWK-009, they're pretty good OOTB. Initial impression, build quality is fine, no visible gap between the joints, cable a little springy. About the sound, I would say they are not so neutral and smooth like RE-400 or have many fun factors like the **** 4in1. They have somewhat fun sound, with good sub-bass rumble, tight and punchy mid-bass, but the mid-bass bleeds a little bit to lower-mid. Mid-range is laid-back with boosted upper-mid. Treble is just right, with sparkles and airiness. Overall they're the mini **** 4in1 without the harsh treble peaks, but clarity and soundstage is not as good. They're lightweight and very comfortable. It's a little tricky to make them sound right, deep insertion make the sound too muddy, shallow insertion works best for me. Just my 2 cents.
Edit: Right after the Seahf, the EINSEAR T2 arrived. OOTB they aren't so good, they are so BIG. Punchy mid-bass but missing sub-bass rumble, treble is neither airy nor sparkling like the Seahf, even worse, there are terrible peaks. The SEAHF is far superior in term of sound quality and ergonomics. I still don't know why you guys rate the Einsear so high.
Just got a new box of goodies.
Updates....
MaGaosi will be soon rolling out the new updated K3 HD version. He will provide a high version and low version to meet different requirements. This is his last message he sent me.
About KZ's latest IEM: KZ ZS5 sounds really great so far, nicely balanced towards neutral with plenty of clarity and a great 3D-like soundstage. I would definitely round them up as part of my top 3 --> SENDIY M1221 being first, KZ K3 (PRO/HD) being a close second, and KZ ZS5 following in third place. I can not rate the KZ ZS5 tops because construction can be a little too fragile for my taste and QC issues that I, myself and several other ZS5 owners encountered so far (though they were miner).
