Slater
I didn't know that there was a specific orientation for the cable, thank you But i noticed that in fact the pins are bend, especially on the left side, maybe because i was used to put the cable on the wrong orientation...
Well luckily there's no need to replace the whole ZS3 itself - just the cable (assuming you can't bend the pins back).
You can order a replacement cable for about $2ish. For a few dollars more than that (~$5), you can get the optional silver plated upgrade cable.
