- Oct 6, 2013
Forte has more quantity in the 20Hz region per that video but it isn't a ton more and it's most noticeable in the rumbling decay of the bass.
The bass in the song I linked is in the 70Hz region.
I think what's throwing me off is that they both attack with about the same weight, have similar sustain but the DD on the Forte has the weightier/more rumbly/fuller decay and that makes sense knowing that it's a DD. Will let it burn in more and report back but you're probably right it will tighten up.
For comparison, assuming universal U18, do you use the same eartips between U18 and Fourte, to make sure the seal is the same?
