RPGWiZaRD
- Jan 31, 2010
All I know is that MizMoxie must be well and truly over seeing messages from RPGWizard with some breathless new observation on the ZO2 - I can relate.
What?
As breathless as you might find them, look at the thread's title
And maybe you won't start another threadwar.... live and let live
Received my revised ZO2 and a thank you card today. The thank you card was signed by what I assume the whole staff which included 4 or 5 people. I don't have the card with me at the moment but it indicated that they appreciated that we stood by them. I thought it was a nice touch and something I can appreciate.
For me, it seems that all that was wrong has been fixed. I do not hear any hiss when using LOD or HO. When I power the ZO2 on, I do not hear any popping. When I turn it off, the music just quits and there is no popping or noise at all. The original ZO still played music when it was off but this revised version does not play music through it when it's powered off. This is for both LOD and HO. By no means I care about this but something I noticed. The volume has been toned down quite a bit. When using LOD, the volume on the iphone is not affected and it is only controlled from the ZO2. The lowest volume setting is at a very comfortable level and by not means is it too loud. When using HO, the volume is so low that I can have the volume on my iphone all the way up and adjust through the ZO2. I think it might be a little too low through HO but it would only affect the person who listens at an unreasonably high level. I don't remember any other issues with the first batch but it seems digiZoid has fixed the problems that we mentioned. I am very happy with the fixed unit and all in all, I believe didZoid has stood behind their product and has done a great job to satisfy their customers. For the International customers, I hope there can be something that can be worked out for the heavy fees associated with shipping because I think the revised version is worth the exchange.
On the point of the ZO2 'V1' 'playing music while in the 'off' position', I am working on the assumption that all I am hearing in that state is the amp stage...
Hmmm? I thought when the ZO2 is 'off' it's in bypass mode = No amp / No SmartVector.
@DannyBai - thank you for those detailed impressions - most enlightening.
On the point of the ZO2 'V1' 'playing music while in the 'off' position', I am working on the assumption that all I am hearing in that state is the amp stage, and turning the SmartVektor on gives me immediate confirmation that I have profoundly changed the sound signature. One thing I will note with the ZO2 is how quickly I become accustomed to the 'base level' SmartVektor as 'normal' - going back to one of my other amps (or straight from the HO) requires a period of adjustment, but I know this from previous attempts to do side-by-side comparisons of kit, particularly amps.
The biggest single change, for me, is the intimacy of the sound with SmartVektor engaged, but its difficult to argue that this is not a toy aimed at the basshead in many of us - with certain cans, its actually too much of a good thing, even at 'base level'. Properly marketed, Digizoid could easily license the technology to a much larger company - I'd like to see SmartVektor integrated into a wide range of gear, on the proviso that it would never be 'on by default', ala Bose and various other lifestyle marques.
The ZO2 is completely off and no music goes through. You are right for the ZO1 and music goes through un-ampep. I don't remember if the first batch of ZO2 allowed music to play through.
I don't know enough about the electronics - perhaps someone from DigiZoid can clarify this. If that were the case, then the 'ZO2 V2' has clearly had this 'bypass mode' disabled. I admit that it makes more sense that the ZO2 wouldnt be able to amplify the incoming signal from your source when its 'off', but very little about the 'ZO2 V1' has been predictable from the day I got it
(note that some amps will automatically turn on when an input signal is present - I cant recall exactly which ones, but the Pico Slim rings a bell)
