helljudgement
- Jul 23, 2009
people that say Pegasus is a scam i think they got a broken unit, but who know maybe it is scam.
any recommendation for R2R DAC
It would help if you could provide more information regarding your sound preference and your past gear/experiences for reference we can make a better recommendation. For starters why do you want R2R? Is there a particular trait that draws you towards the R2R over Delta Sigma? Buzz words like these tend to confuse even experienced hobbyist so all the more important to state your preference. Nevertheless here are some dacs that I personally think fit the Verite.
I'd recommend either the Bifrost 2 or RME ADI 2. Bifrost 2 has a slightly denser tonality and have a slightly deeper stage when compared to the RME it can come across as a bit darkish especially when paired with Verite. The RME is more neutral and a tad more forward sounding then the Bifrost. Feature wise the RME trumps the Bifrost. The RME comes equipped with a built in amp which provides enough power to drive most headphones yet quiet enough to drive sensitive iems but it does sound a bit boring. It also comes with a parametric eq which makes for an attractive AIO unit.
Both are very popular and a good match with the Verite so pick your poison. It should be easy to find reviews of these 2 units online so do your own research before pulling the trigger.
