NutritiousNoodles
That’s how I felt when I saw the closeups in the launch video.pictures like this make it very difficult to not spend oney
Sensitivity is more what you want to look at. At 95db/mw they’re only a bit more power hungry than other ZMFs. The 60hms does tell you they’ll need more current at a given power level though, so that affects amp choice (and is why you don’t want to use an OTL probably as others have mentioned)
Without an output transformer, an OTL's output impedance will be relatively high. I suppose it depends on your tubes (and I'm not an expert in OTL design or tube selection), but the ideal OI for an Arya SE should be less than 4Ω (16Ω if you're going for 2:1), and most OTL's I know are triple or more of that. The OTL will still drive your headphone, but if its OI is too high, you will have very little electrical dampening, which will definitely have audible effects. Whether you like that effect or not is your preference, but it isn't everyone's cup of tea.Surely that depends on the OTL? Mine is driving Arya SE beautifully, so I'd hope Caldera would fall into the same camp.
