Thank you!Howard Feed-N-Wax wood polish and conditioner
Put some on a soft rag, I use flannel, work it in the rag, then polish, let stand a few minutes, then with clean flannel wipe it off.
https://www.amazon.com/Howard-FW001...d+conditioner&qid=1561107033&s=gateway&sr=8-3
ZMF Auteur Thread
- Thread starter PacoTaco
erics75
Auteur owners that also own or have significant experience with the Atticus, i have a question. I got my Teak Auteurs Tuesday, and have been listening excessively since. One thing i'm finding with them vs my beloved Atticus is the mids seem slightly hallow and recessed in direct comparison. I wouldn't say the mids are recessed or hallow in general, just in comparison. Anyone else hearing the same thing? Where it really stands out to me are male vocals. Listening to The Doors, David Bowie, Van Morrison, etc, they sound farther away and less up front. I'm not sure if it's just the larger soundstage and air that's throwing me off, or what, but I keep thinking the mids should be a touch more up front. i'm getting used to it, but when i slip the Atticus on, it immediately seems much more forward. forgot to add, using the Auteur pads only for now until i'm comfortable with the sound. then i'll try the Eikon perf pads.
And shout out to Zach, my quote "B Stock" teaks look amazing! not a single flaw that i can see. when discussing them, he said he was b stocking them because the cups are mismatched. call me crazy, but i dont see it, they're beautiful. i'll post a few pics once i set up my lighting rig so i can properly image them.
I have two Auteurs and the mids seem more forward rather than recessed. Maybe try burning them in for a while? In addition, the Auteur pads are definitely more neutral than the Eikons. Although the Eikon pads make the Auteurs a touch warmer, they are also darker and lessen the soundstage. Hope that helps.
BananaOoyoo
I have both, and Atticus is for sure the warmer headphone.
LCMusicLover
I don't own Atticus. However, I perceived the same thing with my Ether 2. They have a very deep headstage, and some vocals sounded recessed. After a bit of listening, I realized that the 3d stage was literally moving some vocals 'back'. I haven't really noticed that with my Blackwood Auteur -- perhaps a wood difference....the mids seem slightly hallow and recessed in direct comparison...they sound farther away and less up front. I'm not sure if it's just the larger soundstage and air that's throwing me off...
ksorota
And shout out to Zach, my quote "B Stock" teaks look amazing! not a single flaw that i can see. when discussing them, he said he was b stocking them because the cups are mismatched. call me crazy, but i do not see it, they're beautiful. i'll post a few pics once i set up my lighting rig so i can properly image them.
I would suggest some more burn in time before making any judgement on the mids...My first listen with my new to me Cocobollo's was nothing like the first listen of a used pair of Blackwoods I had and i was a bit disappointed. But after about 30-50 hours they hit their stride and now are very full in the mids. The bass has also improved after some burn in time.
I found the Eikon pads to be a fun experience and used them for a few weeks before going back to the more neutral Auteur pads. Back on the Auteur pads I find myself questioning why I ever tried the Eikon pads. Very cool headphone that can change so drastically small pad differences.
Keith
I think it's a matter of burn-in. Out of the box my Auteur had this bloom in the bass that I completely didn't expect it to have. I mean, it sounded like the AFO with more forward mids. But this bloom in the bass disappeared quite quickly, as did the slightly overly sparkly highs. My Auteur is just excellent now. I'm extremely happy with it.One thing i'm finding with them vs my beloved Atticus is the mids seem slightly hallow and recessed in direct comparison. I wouldn't say the mids are recessed or hallow in general, just in comparison. Anyone else hearing the same thing?
erics75
As many have said, I think burn in is the main thing going on here. i'm noticing the bass seems slightly softer but with better textural information, and the highs are losing the hard edge they had when i first gave them a listen. i'm sure some brain burn in is at play as well haha. But the more i listen, the more i'm really loving this set. and you are spot on with your comment about the stage. the Atticus has a moderate size stage with moderate dimensional placement. The Auteur is larger with much more spacing in it's placement. Where the Atticus puts most of the information relatively close to your ears, with only moderate space between them, the Auteur stretches it out in all directions, giving a much more diffuse and open stage. as i'm learning the Auteur's signature, more and more i'm realizing what i mistook for sound recession is actually just the larger stage.I don't own Atticus. However, I perceived the same thing with my Ether 2. They have a very deep headstage, and some vocals sounded recessed. After a bit of listening, I realized that the 3d stage was literally moving some vocals 'back'. I haven't really noticed that with my Blackwood Auteur -- perhaps a wood difference.
erics75
i do love how responsive the zmf's are to pad swapping. i go back and forth between the lambskin and suede ori pads on my Atticus, and it's such a different sounding set depending on the pads. i'll eventually try the eikon perfs on the Auteur but right now i'm still trying to get a sense of this set's base signature. burn in is definitely at play here though, i'm noticing it changing quite a bit as the hours add up. i let it run overnight the last two days while sleeping and that has been very helpful to loosen up those drivers and driver suspensions. the first few hours had me really worried because the treble was so hard and irritating. but it's already calmed down significantly, the hard edge is gone. it's still well extended, but not sibilant at all.I would suggest some more burn in time before making any judgement on the mids...My first listen with my new to me Cocobollo's was nothing like the first listen of a used pair of Blackwoods I had and i was a bit disappointed. But after about 30-50 hours they hit their stride and now are very full in the mids. The bass has also improved after some burn in time.
Keith
Focux
Tried 3 Auteurs yesterday,
Teak, Ambrosia and Manchurian
Ambrosia is the best can I’ve heard
Verite sounded “boring” compared and I’d take Auteur Ambrosia over Utopia anyday
Tested with Feliks Euforia and Echo ^
Been running my Cocobolo and Blackwood through my Euforia. Pure bliss!
Agree to disagree on your assessment of the Verite, but I'm curious to hear what you thought about the Teak Auteur vs the Ambrosia! Did you find they sounded mostly similar??Tried 3 Auteurs yesterday,
Good to hear, as I bought the Feliks Elise at Canjam SoCal last week to run my Walnut Auteurs. Delivery next week, I'm very excited.Been running my Cocobolo and Blackwood through my Euforia. Pure bliss!
Are you using stock tubes and if so, do they really get as hot as some suggest they do?
I am using the PSVANE CV-181 Mk2 Gold tubes along with TS 7236. They do get very hot as I basically use my amp as a heater in my mancave.
