Superunknown2
My advice is to buy it now. It is well worth it, especially with the sale. I have had the LTD Olivewood AC for a few days now. If it helps, I can give my impressions. Before buying, I looked at the reviews on youtube and head-fi. In my experience with other headphones, the reviews are usually pretty accurate, especially once you have several different reviews to average out. The reviews out now seem to be pretty accurate for the AC. I don't think you are going to learn much more by waiting for more reviews. The headphonics review that was just posted looks pretty accurate also. I think the best youtube review is the one by headkarma, since he does a good job describing the softwood versus the hardwood. I originally placed an order for a cherrywood AC, but then decided to change to an LTD because the sound signature from the hardwood was a better fit for me. These are some of the best headphones out right now, cherrywood or LTD, and the price is very good for what you are getting.Same. And also some more impressions from the people who already received it. It's been very quiet here all things considered. So far very strong likes and loves but relatively few in number. Would be great to see more reactions once people are comfortable that they've opened up the drivers sufficiently.
I have a Bifrost 2/64, a Jotunheim 2, and an Echo 2. I also have a AO, VO, VC, and HD800s. If I could only keep one of my headphones, I would keep my LTD AC. In my opinion, unless you are a bass head, or mostly listen to bass heavy genres (as headkarma said), I think the LTD version is an upgrade over the cherrywood. Unless you are a bass head, upgrading from the cherrywood to the LTD is almost like going from an Arya to an Arya Stealth. It is better in many ways, and probably better for more people, though there are exceptions. They are similar, but one comes off as more refined. The Arya was more of a specialist, while the Arya Stealth is more of a generalist. I think the analogy is similar for the AC softwood versus hardwood.
In wavetheory's youtube review of the AO, he mentions that the AO tends to get a bit crowded in the upper-mids when you are listening to rock with heavy electric guitar, and I agree. That is much of what I listen to. Reviews are suggesting a similar issue with the cherrywood AC. I detect none of that whatsoever with the LTD AC, and none of the reviewers do either. Zeos' review of the AO suggested using the Brainwavz pads. I tried that, but it made the AO extremely bass heavy, presumably like a cherrywood AC. I liked the bass heaviness for a bit, but soon it became fatiguing. The LTD AC produces the same amount of bass but makes it is much tighter and punchier. This turns the bass from something that harms rock music to something that adds to rock music. I am more easily fatigued by heavy bass than most, and I think the LTD AC does bass perfectly, without fatiguing me at all. I usually listen to rock/metal/alternative, and prefer more mid-forward sound. I used to have an Aeolus but didn't care for it since it was so warm and the detail wasn't at the level I wanted. The reviews make the Aeolus sound similar in some respects to the cherrywood AC (though most seem to love the Aeolus). I used to have an Eikon, and I agree that the LTD AC is more of a drastically improved Eikon (hybridized with a VC and an AO) than it is a closed back AO. The cherrywood AC is closer to being a closed back AO, only with more bass. For this reason, if you already have an AO, the LTD AC would make more sense. If you don't have a VC and are considering one, then you would be insane not to buy the LTD AC, since that would give you most of what the VC gives you, and so you would no longer need to get a VC at all. I also suspect that the LTD AC provides better sound isolation since the wood is harder.
