mochill
Any effect on soundstage with that mod??
This kinda reminds me of the Pistons dilemma. There were all these trustworthy headfi'ers telling others just where to go to get authentic Pistons, and people STILL ended up going the eBay route to try and save a couple bucks. They ended up getting fakes. $50 is a good price for a working pair of Tenore. Heck, even $60.00 would be a fair price. I paid $54.00 through white rabbit express with all the charges, shipping ect. That's about what I paid for my Tenore through eBay. WRE has been providing quality Tenore to quite a few here, including myself, so just go with WRE. Why risk it for a few bucks? Not worth it to me.
What about a piece of comply or shure foam? Looks like youtried them
Have you tried filling the whole space with them?
I think sealing and poking a needle hole will be best
I tried foam from shure olives, but didn't have any complys at hand. It's cumbersome to work in such a small space and I was in constant fear of damaging a cable. With higher density material, you can't quite fill the whole space, as you need to leave some room for the cables.
I agree, but haven't found a way to reliably tape the vent. The solder points are right next to it and the flat part of the back plate is extremely small.
I believe that small piece of styrofoam lets some air escape, because of the uneven surface around the vent. I'll wait a few days and see if the sound signature remains stable, before closing them up for good.
Quite surprisingly, low end extension is still excellent, even though a major part of the back cavity is now filled with foam.
What about stuffing cotton in to fill the entire area? It would fill more but allow some air perhaps? While shaping around the cable.
Maybe pull apart a few cotton swabs?
Tenore's back vented driver design.
I think all DD are back vented.
picture is worth a thousand words
Maybe, but I agree with Inks and SilverEars that restricting the airflow through the vent seems to be the most important part. Also, no harm in leaving some room for further improvement to more experienced DIYers like you.
That said, would be interesting to see Rin have a go at these...
So I've been listening to the tenore today vs. the kc06. It's interesting. I definitely have been hearing what some people described in the past about soft treble or not dynamic or lifelike. Only relatively speaking that is, as the tenore is superb in any configuration. But I had been using the stock tips for a while now because they have been fitting really well. However, they fit well in a medium/shallow depth. I switched back to the smallish mh1 tips that are narrow or long proportion-wise. These allow me to wear them a bit more shallow with a full seal. I always thought the mh1 tips made things bassier, but that's because they always fit so nicely that I pushed them in to a medium depth or so. Needless to say, the mh1 tips are now my favorite bar none. The slightly more shallow fit not only slightly lowers the bass to how I used to remember it, but it makes the treble sound almost perfectly linear.
I now compare them directly to the kc06 and the treble doesn't sound very soft in comparison like the stock tips were for me. In fact, it's fairly comparable to the kc06 in depth and distinction, but it's more linear overall from bass to treble. Wow. I remember hyping the hell out of these because they were er4s linearity with a bit more sub bass (which to me is perfect). But as time went on I swore my set got bassier. But I think my tenore tips must have been softening and i was pushing them in deeper over time? Not sure. They lately don't fit perfectly shallow for me and required too much messing around to get the best sound without pushing them in a little further. The mh1 fits very nicely shallower without this hassle. Super awesome! I still love the kc06, but I was only really digging them because they were offering me more dynamic sounding clarity. The tenores now are comparable in that regard!
The moral of the story is that tips are crucial. Even comparing them side by side I never really noticed a "huge" difference. But now that I've been exclusively using the stock tips I had become very familiar with the overall tone. And even though a direct comparison still isn't drastic, as I listen to a song overall it becomes quickly apparent how open and more distinct treble details are. So I think one key of the tenore is definitely good tip fit/seal and probably as shallow as is reasonably possible if you have similar ears to mine. I could see how different ear lengths could make these simply never sound the same across users. I'l try to eq eq to demonstrate the tip changes to my ears later if I have a chance...
