I am only judging from the pictures that the Fidue A71 will fit me fine since I rarely had problems with bullet-designed IEM's. I am gonna wear them straight down too. Do you think deep insertion would be possible?
On the other hand I had issues with the fit and islotation with the Havi B3 p1 and KC06A.
I also don't really like the new design of the Duoza and wish they kept the old designs, because I really prefer a deeper insertion.
I have fit issues with the B3 Pro 1 too in that it hurts my ears and haven't tried the Ostry. I thought the Fidue A71 was gonna fit fine because I didn't read very much(but did read some) about potential fit issues & tip rolling like the B3 or A83. The housing is not really shaped or designed similar to something like Tenore and fits way different imo. The Tenore is a simple deep insertion fit, but the A71 is almost shallow/mid insertion. It is just oddly shaped for straight-down wear even without the memory wire I would think. Though removing it should help a ton. I must have finicky ears in general or I just priortize comfort and insertion more than most, idk.
I don't know if the Duoza will fit me either, but I think its worth a try. I mean that is why I'm here
