We all have our preferences and our biases (no doubt). Based on sacd lover’s assessment when comparing SP amps or even when comparing them against any other manufacturer it’s next to impossible to compare one to another because each SP amp is usually built differently and can sound different with different tube rolling options as well. With 100s of different voicing choices it could be a blessing or just make your head spin. As I’ve mentioned before, I believe as much as SP provides options to the listener it still is limited to Mikhail’s voicing preference, design, and design philosophy. And the same holds true for any amp maker.
I remember reading impressions from an old Florida meet when Tyrion had his EC2A3 and Head-Fiers in back-to-back comparisons against the MPX3 preferred the EC2A3 by a good margin. This holds true with Mikey01’s opinion as it does coincidence with my take and we had both these amps in our possession for weeks to compare.
Just to toot Craig’s horn, he works with Belkin Labs, Cerwin Vega and in the past I believe Carnegie hall, doing research, design, prototypes as well as building amps. This is just to name a few of the many notables. And can’t forget Moth Audio.
Enough cannot be said about how the source, cables, and headphones can affect either positively or negatively a listeners experience along with their personal preferences. And certain equipment such as an amp can be pointed to, but it is equally likely that it could be the source, headphones, cables or the recording. Even some sort of combo at play.
Large So Cal meets are just plain noisy. It was nice spending the night there without any distractions, but the equipment and music.
Just for clarification, under ideal listening conditions I compared the PPX3 balanced slam against the ZD with my source, cables, headphones, and music. On at least two separate occasions I compared my EC2A3 against the MPX3 w/ 6SN7s again under ideal listening conditions. As well as comparing my EC2A3 against the ZD. I know what I heard and what I preferred. IMO and in general, the 6SN7 is a better sounding and more musical tube than any 5687.
I’ve very sensitive ears to high frequencies and usually within seconds or sometimes even minutes I’ll know whether a certain amp, headphones, source, or cable is going to be fatiguing. I've had no such experience with the ZD. I listened with my HD650; sources: moth dac, 508.24, Apollo; cables: cardas neutral reference, AVpure, quality copper cable.
It’s fine to disagree, but let’s not forget for the most part this is a subjective art. I find it very suspect when someone deals in absolutes. Especially knowing that all the amps mentioned are of the utmost caliber.
Originally Posted by tyrion
Listen to both and make up your own mind.
Ditto
